I have a Xerox Versalinkc600 network printer and Xerox Debian package printer driver installer, which I have downloaded. How do I (step by step) install the printer driver?
Asked
Active
Viewed 99 times
You can install local DEB packages using the dpkg tool, and you do so by running the following command:
sudo dpkg -i <packagename>.deb
Make sure to replace <packagename> with the actual name of the package.
There is also a chance you may get dependency errors the first time you run this. If so, run sudo apt --fix-broken install, and then re-run the dpkg command and the package will install fine.
Daniel M.
- 2,046
