after realizing I installed the wrong Ubuntu version(20.04), I wanted to remove it and then install the correct version(18.04).
I used this guide:
https://itsfoss.com/uninstall-ubuntu-linux-windows-dual-boot/
However, steps 6 and 8 do not work for me. Therefore, I tried solutions from here:
https://unix.stackexchange.com/questions/259069/how-to-start-a-windows-partition-from-the-grub-command-line
However, insmod chain throws the "Error" unsupported filesystem.
And, the approach using diskpart (from a repair usb stick) doesn't work, as step 9 (Z: dir) returns "File not found".
Could someone help me fix my Windows partition?
KalvinB
  • 113
boot from your Ubuntu live CD/ USB and follow instructions given in link of Boot-Repair page. Follow the second option:
install Boot-Repair in Ubuntu
  • connect to the Internet
  • open a new Terminal, then type the following commands (press Enter after each line):
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
And follow Recommended repair for more detail.
You can also refer to website of Boot-Repair
Ajay
  • 688
