I need to stop ubuntuone-syncd but I don't know where to find the service that I need to stop.
Ubuntu One comes with the commandline tool u1sdtool to control it.
Basically the gui control panel cannot quit the syncdaemon but can connect/disconnect it.
If you need to control syncdaemon start/stop it
you have u1sdtool --start and u1sdtool --quit
If you need to connect/disconnect it
you have u1sdtool --connect and u1sdtool --disconnect commands
See u1sdtool --help for all the available commands.
You can do connect/disconnect through control panel gui as well.
There is a indicator for ubuntuone as well: What Application Indicators are available?
If you need to disable ubuntuone from autostarting at login
Syncdaemon is autostart service. So if you just need to disable the autostart part when you login to your session. Go to /etc/xdg/autostart and do
sudo sed --in-place 's/NoDisplay=true/NoDisplay=false/g' ubuntuone-launch.desktop
and disable it from startup-applications
- 24,306
Not sure if this works, but you can stop (and start) the client by using the commandos
u1sdtool --quit
u1sdtool --start
It seems it is is started via dbus daemon.
apt-get remove ubuntuone-client will uninstall it.
Or you could rename /usr/share/dbus-1/services/com.ubuntuone.SyncDaemon.service and restart dbus, that might work as well.
- 2,202
In a terminal, first list all services to ensure you call stop on the correct one:
service --status-all
then (still in the terminal)
service [insert name] stop
and to restart:
service [insert name] start
NB: the square brackets are not part of the command and should be removed :-)
- 1,584
