I have a directory on my Ubuntu server that has many subdirectories and files. I want to download entire folder, so I used this command:
scp -r myuser@mywebsite.com:/path/to/target_directory /path/to/local_directory
So target_directory ends up in /path/to/local_directory/target_directory. This is fine so far.
The problem: target_directory is not so big (around 50MB) but has many tiny files. scp download files one by one, which takes too long. So I'm thinking may be there's a way to compress the directory and download it (optionally, without keeping the compressed file on the server). I think it's achievable but not sure how.
Note: I use Mac for my local machine.
evilReiko
  • 185
Thanks to @muru for answer and explanation. I'm posting this to remind myself and anyone else who might need this.
rsync is really fast! This is how to do it with rsync:
rsync -azP myuser@mywebsite.com:/path/to/target_directory/ /path/to/local_directory
  • -a will (recursively) copy everything
  • -z will compress the files,
  • -P will show you progress bar for each file
rsync allows you to resume downloading in case of interruption or network failure just by running same command.
Note: the / in the right end of the source /path/to/target_directory/ means it will copy the content of target_directory (not the directory itself). If you want to copy the directory itself then remove this trailing slash.
Read more: https://www.digitalocean.com/community/tutorials/how-to-use-rsync-to-sync-local-and-remote-directories-on-a-vps
muru
  • 207,228
evilReiko
  • 185
You don't really need compression, if the problem is that there are many small files. Use tar to make an archive on Ubuntu, and instead of saving the archive to a file, send it to stdout (the default for Ubuntu's GNU tar when there's no file specified) and read the tar file on the other end:
ssh ubuntu-server tar c -C /path/to/target_directory . | tar xvf - -C /path/to/local_directory
Or use a smarter tool like rsync.
muru
  • 207,228
