I know a very fast repository I often use to install packages, I would dearly like to use this when I am setting up Ubuntu, the mirror used by setup when the region is choosen is usually very slow, this results in apt configuration taking a long time.
I usually have to remove network connectivity from the machine I am setting up and the setup process will quickly complete. I then use synaptic to change to the fast repository before installing all those large packages I need, it would be much smoother though, if I did not have to do this and could feed the setup process repository information before hand.
I am wondering if I use the synaptic package manager in the live session and select a repository if the selected repository will be the one used during setup or will the setup process use the one it thinks is best usually a local mirror?
Jorge Castro
  • 73,717
Sabacon
  • 41,474
Boot into the live session (not installer), open synaptic, change repository, refresh and without restarting open Install Ubuntu from Desktop.
Ubuntu live cd has a virtual RAM drive where changes are recognised.
