I faced this issue when I want to use sudo command :
sudo: /etc/sudoers is owned by uid 1000, should be 0
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
then I tried a solution from a similar question in order to change the owner back to the root:
$ pkexec visudo
also I tried this one
$ pkexec chown root:root /etc/sudoers /etc/sudoers.d -R
but I have faced another issue with these commands:
Error getting authority: Error initializing authority: Could not connect: No such file or directory
So is there a solution to this issue?
Full shell issue snippets:
ubuntu@LAPTOP-D4T16P7J:~$ sudo -i
ubuntu@LAPTOP-D4T16P7J:~$ pkexec visudo
ubuntu@LAPTOP-D4T16P7J:~$ pkexec chown root:root /etc/sudoers /etc/sudoers.d -R
This is my /etc/sudoers file:
ubuntu@LAPTOP-D4T16P7J:~$ cat /etc/sudoers
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults        env_reset
Defaults        mail_badpass
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root    ALL=(ALL:ALL) ALL
# Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL
# Allow members of group sudo to execute any command
%sudo   ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
OS info:
  • Ubuntu WSL2.
The answer was as follow:
  • access root user by issuing this command in windows command line (CMD):
    wsl -u root
  • change ownership of /etc/sudoers file to the root:
Thanks to @Terrance for him help.
Kulfy
  • 18,154
I've had similar issue.
using wsl -u root resulted in error.
Open cmd, run wsl -l to get distribution name.
In my case output was Ubuntu-18.04
run wsl -d Ubuntu-18.04 -u root
You should be using root now.
run chmod 440 /etc/sudoers
temo
  • 111
