I have recently upgraded to ubuntu 20.04 LTS, it works charmingly but all I want is to hide grub menu on booting. Yes, I tried to edit /etc/default/grub. Timeout is set to 0 sec in default, and I'm still seeing the grub menu on startup with timeout 30 sec.
I tried to edit using grub-customizer and no luck
Startup screen
timeout is showing 30 secs
VidathD
  • 2,829
You are using lvm or btrfs for your / partition.
This is made by design, because grub can't write to either of those. This may lead to unablity to enter grub after a boot failure.
If you are sure that's not a problem for you, add GRUB_RECORDFAIL_TIMEOUT=0 to /etc/default/grub and run
sudo update-grub
Otherwise consider making a separate /boot partition formatted to ext2.
Pilot6
  • 92,041
-1
Try changing grub settings,
Start termina(Ctrl + Alt + T)and type in terminal:
sudo -H gedit /etc/default/grub
Change GRUB_HIDDEN_TIMEOUT_QUIET=false to
GRUB_HIDDEN_TIMEOUT_QUIET=true
Save and exit
After that type in terminal:
sudo update-grub
MrShadow
  • 147
