I am trying to install CUDA for Deep Learning purposes and I have followed the instructions that can be find here.
Everything seems is going good but when finally I run the command sudo apt-get install cuda-10-0 (same if I do not specify the CUDA version), I get the following error:
Reading package lists... Done
Building dependency tree
 cuda-10-0 : Depends: cuda-runtime-10-0 (>= 10.0.130) but it is not going to be installed
             Depends: cuda-demo-suite-10-0 (>= 10.0.130) but it is not going to be installed
I have searched similar errors on web but there is not something exactly like this.
Edit:
I have tried to do it on the other way, using the .run file after accept the conditions of the License what I get is: Installing the NVIDIA display driver... The driver installation has failed due to an unknown error. Please consult the driver installation log located at /var/log/nvidia-installer.log.
= Summary =
Driver:   Installation Failed
Toolkit:  Installation skipped
Samples:  Installation skipped
When I check the logs in that file I see:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Wed May  6 14:12:03 2020
installer version: 410.48
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
    ./nvidia-installer
    --ui=none
    --no-questions
    --accept-license
    --disable-nouveau
    --no-cc-version-check
    --run-nvidia-xconfig
    --dkms
Using built-in stream user interface
-> Detected 16 CPUs online; setting concurrency level to 16.
ERROR: An NVIDIA kernel module 'nvidia-drm' appears to already be loaded in your kernel.  This may be because it is in use (for example, by an X server, a CUDA program, or the NVIDIA Persistence Daemon), but this may also happen if your kernel was configured without support for module unloading.  Please be sure to exit any programs that may be using the GPU(s) before attempting to upgrade your driver.  If no GPU-based programs are running, you know that your kernel supports module unloading, and you still receive this message, then an error may have occured that has corrupted an NVIDIA kernel module's usage count, for which the simplest remedy is to reboot your computer.
ERROR: Installation has failed.  Please see the file '/var/log/nvidia-installer.log' for details.  You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Ubuntu 19:
