I recently installed Ubuntu 12.04 (beta 2) on my HP mini 110-4117, but I cant control screen brightness. The Fn + F2 , Fn + F3 keys don't work. System Settings > Brightness and Lock doesn't provide any means of controlling screen brightness.
How can this be fixed? Thank you.
Here is what worked for me. I got the solution from the folowing links. Check them out or read the summary below.
http://linuxon1001p.blogspot.com/2010/03/fixing-brightness-controls.html
Desktop doesn't remember brightness settings after a reboot
Summary:
  1. Edit your /etc/default/grub file:
    sudo gedit /etc/default/grub
  2. Add the options "acpi_osi=Linux acpi_backlight=vendor" to the GRUB_CMDLINE_LINUX_DEFAULT line. It should look like this:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux acpi_backlight=vendor"
    original line was:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
  3. Update grub configuration!!!! - do not forget to do this, the configuration change will not be set up if you don't run the next command:
    sudo update-grub
This worked for me after trying a lot of other solutions. I have a HP dv7-6090ef with hybrid graphics Intel/AMD.
Have fun using Ubuntu!
bubolex
  • 357
With Ubuntu 14.04, Acer E1-572, this works: Create a file /usr/share/X11/xorg.conf.d/20-intel.conf and put in it:
Section "Device"
Identifier "card0"
Driver "intel"
Option "Backlight" "intel_backlight"
BusID "PCI:0:2:0"
EndSection
