In Ubuntu 20.04, I type sftp at the command line, and I see there is a -i parameter.
When I try it
sftp user@site.com -i Key.ppk
it acts like maybe the command is not recognized and gives me the syntax, as though I had typed sftp -h.
I have tried keyfiles of both .ppk format, and .pem format. The key is the current directory, and I tried with and without ./ in front of the filename. Even if the key was bad, wouldn't it give some useful error message? I have also tried -i=keyfile, but I don't think that's the proper syntax (it continues to prompt for a password in that case, as though ignoring the -i parameter.
I was able to connect with a different user (to same server) that had password only authentication.
Referencing this similar question:
Ángel Araya
  • 1,552
NealWalters
  • 121
Per the help message, order matters, the -i flag comes before the destination so it should be
sftp -i key user@domain.tld
Ángel Araya
  • 1,552
Apparently the -i must come before the user@server.
sftp -i Key.ppk user@site.com
Now I'm getting a different error, but at least I can move forward with debugging.
NealWalters
  • 121
