-1
I'm working on a Ubuntu 18.04.2 LTS. I wanted to upgrade R but I constantly get stuck. I've entered
sudo gedit /etc/apt/sources.list
Where I add
deb https://cloud.r-project.org/bin/linux/ubuntu bionic-cran40/
and saved.
Then I got this error message:
** (gedit:27981): WARNING **: 21:44:53.588: Set document metadata failed: Setting attribute metadata::gedit-position not supported
When I tried previously it worked and indeed I came here for a problem (public-key not found) which I encountered later in the process (after typing sudo apt-get update). Now I'm stuck even earlier..:((
I didn't find any thread with answers about this issue. Can someone help me? Thanks
Giulia
The README file on the site you want to download packages from says:
The Ubuntu archives on CRAN are signed with the key of "Michael Rutter <marutter@gmail.com>" with key ID 0x51716619e084dab9.  To add the key to your system with one command use (thanks to Brett Presnell for the tip):
    sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys E298A3A825C0D65DFD57CBB651716619E084DAB9
So there goes the answer to your second problem.
That's not a problem at all -- just gedit can't save your last editing position.
jpalecek
  • 261
