-1
What I did
I wanted to clean install Ubuntu 20.04 system on my machine which previously ran windows 10 on it. This is what i did:
  1. Downloaded Ubuntu 20.04 iso from my windows 10
  2. Downloaded Rufus from my windows 10
  3. Made fat32 boot-able usb (16Gb) for Ubuntu
  4. From boot menu I selected the UEFI partition of Ubuntu pendrive
  5. Without a delay I was taken to Ubuntu installation setup
  6. I clicked on install Ubuntu (with English language selected)
  7. Again selected English for keyboard layout.
  8. Software and third party tab I clicked continue
  9. I selected do something else
  10. I deleted all the partitions of windows (I forgot to delete one partition of windows recovery environment as I thought it was pointing to my windows istallation media)
  11. created the usual Ubuntu partitions efi and root
  12. selected efi partition and installed the system.
  13. System worked fine! Everything was good!
At this time though my PSU was malfunctioning. (Monitor screen would fluctuate by going into power saving mode) My windows system used to crash to because of PSU problem so I switched to light weight Ubuntu system. System was working fine but when I restarted it after putting in username and password my PC would go into power saving mode (PSU problem). I tried rebooting for 2-3 times but same problem. I Could not replace the PSU (Because of lock down!) so I removed my GPU to reduce power requirements. On the next reboot though there were no fluctuations in monitor screen but I just got a Blank screen with a '_' (Single underscore) On it. So I decided to reinstall Ubuntu!
  1. I plugged in the same USB stick which I used before
  2. In the boot menu selected UEFI partition of the USB
  3. This time Instead of taking me to the installation setup directly I had this command lines on my screen: https://i.sstatic.net/sP8gh.jpg
  4. After some loading I was on Ubuntu installation setup page.
  5. As usual selected setup language as English
  6. when I clicked next on keyboard layout tab (English was selected) setup loaded for 7-8min
  7. On the next tab the setup just kept loading!
  8. So I hit the reset button on my CPU
  9. After again loading and loading I selected Try Ubuntu
  10. Again there was this: https://i.sstatic.net/uEvqi.jpg screen! and after some loading Live session started.
  11. I Started setup Again from here.
  12. It took me 30min to reach to something else step of Installation (each step took 10min to load)
  13. After that For making each partition It took 5-6Min
  14. Installation luckily started and I had I/O Error. I clicked retry and everything looked good.
  15. suddenly Installation stopped with executing update-grub failed error.
  16. I started gparted and it kept scanning disk!
  17. I performed Smart Data and self test this was the result: https://i.sstatic.net/XhanN.jpg (OK)
  18. When I try installing again IT gets stuck on the third party software indefinitely!
All I have right now is Ubuntu installation media. I don't think now the PSU is at fault as There are no fluctuations. Here are my BIOS settings (I don't know that much but I thought I should list these) : https://i.sstatic.net/8oQ2i.jpg: https://i.sstatic.net/l8A2W.jpg: https://i.sstatic.net/S0ajI.jpg: https://i.sstatic.net/QlYiI.jpg: https://i.sstatic.net/SrKzP.jpg:
As I have no system installed currently and doing everything on live session please tell me what should I do accordingly. Also I am not a pro! please help because I cannot find proper answers online regarding my current situation. Thank you!
I changed my PSU to cooler master msw white 650W this solved my graphic card and power issues. The main problem, which I thought was my Hard drive. Even after checking my hard drive using different software everything was showing fine. The problem was the SATA cable! I changed it to new one.
