10
Currently having major issues with thunderbolt ethernet adapter.
The device is a "Razer Core X" thunderbolt eGPU enclosure which has a built in USB3 hub and gigabit ethernet port. Essentially a very powerful dock with its own GPU (utilizing the 4 lanes of PCIe on the thunderbolt port).
The same issue occurs if I use the built in ethernet port or if I plug in my own USB3 ethernet adaptor into the USB3 hub on the dock. The issue does not occur if I bypass the thunderbolt dock and plug an ethernet adaptor in directly (although this kind of defeats the purpose of the dock).
The same issue also occurs on different laptops that both use this dock. My work laptop is on 18.04 and my new personal laptop is on 20.04 and both versions of Ubuntu on both laptops have the exact same behavior.
When the ethernet fails it is no longer able to resolve DNS nor can I even ping anything on my local network, but the device still appears "connected" in the NetworkManager UI. When I toggle the connection off/on then it shows "Connecting" and stays stuck there permanently.
When I check dmesg/syslog I see the exact same bunch of errors every single time. Below is an example of the error. Here you can see in the logs I reload the driver via modprobe which causes connection to work again briefly. Then the exact same error and symptoms occur moments later:
[SAME ERROR REPEATED ~20 times]
[  543.814402] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000425e6e3f0 trb-start 0000000425e6e2e0 trb-end 0000000425e6e2e0 seg-start 0000000425e6e000 seg-end 0000000425e6eff0
[  543.815185] xhci_hcd 0000:0c:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 13
[  543.815186] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000425e6e400 trb-start 0000000425e6e2e0 trb-end 0000000425e6e2e0 seg-start 0000000425e6e000 seg-end 0000000425e6eff0
[  543.815271] xhci_hcd 0000:0c:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 13
[  543.815272] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000425e6e410 trb-start 0000000425e6e2e0 trb-end 0000000425e6e2e0 seg-start 0000000425e6e000 seg-end 0000000425e6eff0
[  543.815356] xhci_hcd 0000:0c:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 13
[  543.815357] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000425e6e420 trb-start 0000000425e6e2e0 trb-end 0000000425e6e2e0 seg-start 0000000425e6e000 seg-end 0000000425e6eff0
[  543.815822] xhci_hcd 0000:0c:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 13
[  543.815823] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000425e6e430 trb-start 0000000425e6e2e0 trb-end 0000000425e6e2e0 seg-start 0000000425e6e000 seg-end 0000000425e6eff0
[  609.127969] usbcore: deregistering interface driver ax88179_178a
[  609.128443] ax88179_178a 10-1:1.0 enx90203a1c2b65: unregister 'ax88179_178a' usb-0000:0c:00.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet
[  609.643604] ax88179_178a 10-1:1.0 eth0: register 'ax88179_178a' at usb-0000:0c:00.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 90:20:3a:1c:2b:65
[  609.645089] usbcore: registered new interface driver ax88179_178a
[  609.646672] ax88179_178a 10-1:1.0 enx90203a1c2b65: renamed from eth0
[  612.705215] ax88179_178a 10-1:1.0 enx90203a1c2b65: ax88179 - Link status is: 1
[  612.735735] IPv6: ADDRCONF(NETDEV_CHANGE): enx90203a1c2b65: link becomes ready
[  652.991795] xhci_hcd 0000:0c:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 13
[  652.991799] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000384cb4280 trb-start 0000000384cb4260 trb-end 0000000384cb4260 seg-start 0000000384cb4000 seg-end 0000000384cb4ff0
[  652.991859] xhci_hcd 0000:0c:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 13
[  652.991862] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000384cb4290 trb-start 0000000384cb4260 trb-end 0000000384cb4260 seg-start 0000000384cb4000 seg-end 0000000384cb4ff0
[  652.991944] xhci_hcd 0000:0c:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 13
[  652.991945] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000384cb42a0 trb-start 0000000384cb4260 trb-end 0000000384cb4260 seg-start 0000000384cb4000 seg-end 0000000384cb4ff0
[  652.992030] xhci_hcd 0000:0c:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 13
[  652.992032] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000384cb42b0 trb-start 0000000384cb4260 trb-end 0000000384cb4260 seg-start 0000000384cb4000 seg-end 0000000384cb4ff0
[  652.992121] xhci_hcd 0000:0c:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 13
[  652.992122] xhci_hcd 0000:0c:00.0: Looking for event-dma 0000000384cb42c0 trb-start 0000000384cb4260 trb-end 0000000384cb4260 seg-start 0000000384cb4000 seg-end 0000000384cb4ff0
That "transfer event" error is in the logs every single time I check them after noticing the symptoms and the timestamp in syslog appears to correspond precisely to the moment the network stops working. As you can see from this run there is no other log output between loading the driver and experiencing the issue.
When I google that error message there are multiple articles talking about thunderbolt bandwidth management issues, but every post I can find is years old and just says it's fixed in the kernel now. But it doesn't seem to be fixed for me (5.3.0-51-generic). The error does occur much more quickly when I am doing something that requires more network bandwidth (like streaming a movie) so that does seem to point to thunderbolt bandwidth issues, but again I cannot find a fix/supposedly this was all fixed years ago.
Linked here is my output from the networking diagnostic script: https://paste.ubuntu.com/p/FmG8hGzkXV/
I've tried disabling autosuspend (using powertop) of both the ethernet device and the USB bus that the device is attached to, but it does not help. My laptops do not appear to have laptop-mode-tools nor tlp installed.
Can someone please help me figure out what is going on? I feel like a thunderbolt device like this should be able to work on Ubuntu. If anything I expected issues with the GPU part of the eGPU but that is working fine as I am currently typing on dual 4k monitors being driven by the dock, the only issue is with the ethernet (keyboard, mouse, usb sound card all work fine when plugged into dock).
gnomed
  • 589
