I cannot manage to make my touchscreen to work properly on a fresh installation of Ubuntu 20.04. On the login screen I can still touch the screen to select the user and the password edit box. Even in the first few seconds after login to Gnome/Ubuntu desktop the touchscreen stays responsive for a few seconds but then stops working (just enough time to start a terminal..)
Informations
- Laptop/Convertible: HP Spectre x360 13-4230ng
- Touchscreen: SYNAPTICS Synaptics Touch Digitizer V04 (according to
xinputandevtest) - Driver used in the xorg-server:
libinput(I triedevdev, but then even the touchpad did not respond anymore, so I switched back to libinput)
To me this seems like a strange problem with the Xorg driver, but I cannot figure out what's wrong.
Using evtest I found out that the touchscreen sends signals as long as the Xserver of the Gnome/Ubuntu session is not started yet. After that it does not send signals anymore.
The fact that I had the touchscreen working during the first session makes me quite sure that there should be a fix for this, or at least a workaround. Maybe there are some configuration files that were created during the first start of the Gnome/Ubuntu session? I tried to remove ~./config/dconf/user, but this did not help. Are there any others? Is there another Xorg driver that I could try?
Just to add some more information I append the relevant part of my Xorg.log here:
[ 17.425] (II) config/udev: Adding input device SYNAPTICS Synaptics Touch Digitizer V04 Mouse (/dev/input/event4)
[ 17.425] (**) SYNAPTICS Synaptics Touch Digitizer V04 Mouse: Applying InputClass "libinput pointer catchall"
[ 17.425] (II) Using input driver 'libinput' for 'SYNAPTICS Synaptics Touch Digitizer V04 Mouse'
[ 17.483] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 31 paused 0
[ 17.484] (**) SYNAPTICS Synaptics Touch Digitizer V04 Mouse: always reports core events
[ 17.484] (**) Option "Device" "/dev/input/event4"
[ 17.484] (**) Option "_source" "server/udev"
[ 17.487] (II) event4 - SYNAPTICS Synaptics Touch Digitizer V04 Mouse: is tagged by udev as: Mouse
[ 17.487] (II) event4 - SYNAPTICS Synaptics Touch Digitizer V04 Mouse: device is a pointer
[ 17.488] (II) event4 - SYNAPTICS Synaptics Touch Digitizer V04 Mouse: device removed
[ 17.488] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:06CB:16F9.0001/input/input13/event4"
[ 17.488] (II) XINPUT: Adding extended input device "SYNAPTICS Synaptics Touch Digitizer V04 Mouse" (type: MOUSE, id 10)
[ 17.488] (**) Option "AccelerationScheme" "none"
[ 17.488] (**) SYNAPTICS Synaptics Touch Digitizer V04 Mouse: (accel) selected scheme none/0
[ 17.488] (**) SYNAPTICS Synaptics Touch Digitizer V04 Mouse: (accel) acceleration factor: 2.000
[ 17.488] (**) SYNAPTICS Synaptics Touch Digitizer V04 Mouse: (accel) acceleration threshold: 4
[ 17.490] (II) event4 - SYNAPTICS Synaptics Touch Digitizer V04 Mouse: is tagged by udev as: Mouse
[ 17.490] (II) event4 - SYNAPTICS Synaptics Touch Digitizer V04 Mouse: device is a pointer
[ 17.491] (II) config/udev: Adding input device SYNAPTICS Synaptics Touch Digitizer V04 Mouse (/dev/input/mouse0)
[ 17.491] (II) No input driver specified, ignoring this device.
[ 17.491] (II) This device may have been added with another device file.
[ 17.492] (II) config/udev: Adding input device SYNAPTICS Synaptics Touch Digitizer V04 (/dev/input/event5)
[ 17.492] (**) SYNAPTICS Synaptics Touch Digitizer V04: Applying InputClass "libinput touchscreen catchall"
[ 17.492] (II) Using input driver 'libinput' for 'SYNAPTICS Synaptics Touch Digitizer V04'
[ 17.493] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 32 paused 0
[ 17.493] (**) SYNAPTICS Synaptics Touch Digitizer V04: always reports core events
[ 17.493] (**) Option "Device" "/dev/input/event5"
[ 17.493] (**) Option "_source" "server/udev"
[ 17.496] (II) event5 - SYNAPTICS Synaptics Touch Digitizer V04: is tagged by udev as: Touchscreen
[ 17.496] (II) event5 - SYNAPTICS Synaptics Touch Digitizer V04: device is a touch device
[ 17.496] (II) event5 - SYNAPTICS Synaptics Touch Digitizer V04: device removed
[ 17.496] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:06CB:16F9.0001/input/input14/event5"
[ 17.496] (II) XINPUT: Adding extended input device "SYNAPTICS Synaptics Touch Digitizer V04" (type: TOUCHSCREEN, id 11)
[ 17.496] (**) Option "AccelerationScheme" "none"
[ 17.496] (**) SYNAPTICS Synaptics Touch Digitizer V04: (accel) selected scheme none/0
[ 17.496] (**) SYNAPTICS Synaptics Touch Digitizer V04: (accel) acceleration factor: 2.000
[ 17.497] (**) SYNAPTICS Synaptics Touch Digitizer V04: (accel) acceleration threshold: 4
[ 17.499] (II) event5 - SYNAPTICS Synaptics Touch Digitizer V04: is tagged by udev as: Touchscreen
[ 17.499] (II) event5 - SYNAPTICS Synaptics Touch Digitizer V04: device is a touch device
[ 17.500] (II) config/udev: Adding input device SYNAPTICS Synaptics Touch Digitizer V04 (/dev/input/mouse1)
[ 17.500] (II) No input driver specified, ignoring this device.
[ 17.500] (II) This device may have been added with another device file.
