-1
I tried updating from 19.10 to 20.04, but in the process I keep getting this warning:
(I translated the message so it might be slightly different)
Insufficient free disk space
The version upgrade has stopped: 1.780 M of free disk space is needed "/ var". Free at least another 1,225 M of space on «/ var». Remove temporary packages from another installation with the "sudo apt clean" command.
I used the command, but after tryig again the space needed didn't change.
This is the space that the folders take in /var displayed with ls -al
drwxr-xr-x 16 root root      4096 mar 11 14:36 .
drwxr-xr-x 20 root root      4096 feb 19 21:57 ..
drwxr-xr-x  2 root root      4096 mag  2 12:24 backups
drwxr-xr-x 18 root root      4096 feb 15 14:42 cache
-rwxrwxrwx  1 root root      2708 mar 11 14:36 .com.zerog.registry.xml
drwxrwsrwt  2 root whoopsie  4096 mag  2 12:46 crash
drwxr-xr-x  2 root root      4096 feb  6 17:54 games
drwxr-xr-x 74 root root      4096 mag  3 21:19 lib
drwxrwsr-x  2 root staff     4096 ott 14  2019 local
lrwxrwxrwx  1 root root         9 dic 25 10:08 lock -> /run/lock
drwxrwxr-x 14 root syslog    4096 mag  3 21:21 log
drwx------  2 root root     16384 dic 25 10:04 lost+found
drwxrwsr-x  2 root mail      4096 ott 17  2019 mail
drwxrwsrwt  2 root whoopsie  4096 ott 17  2019 metrics
drwxr-xr-x  2 root root      4096 ott 17  2019 opt
lrwxrwxrwx  1 root root         4 dic 25 10:08 run -> /run
drwxr-xr-x 17 root root      4096 mag  2 12:45 snap
drwxr-xr-x  7 root root      4096 ott 17  2019 spool
drwxrwxrwt 13 root root      4096 mag  3 21:44 tmp
Output of df -h (without the dev/loops)
File system     Dim.  Used  Avail. Use% Mounted on
udev            1,9G     0    1,9G   0% /dev
tmpfs           385M  2,0M    384M   1% /run
/dev/sda3        14G   12G    2,0G  86% /
tmpfs           1,9G  103M    1,8G   6% /dev/shm
tmpfs           5,0M     0    5,0M   0% /run/lock
tmpfs           1,9G     0    1,9G   0% /sys/fs/cgroup
/dev/sda7        82G   28G     51G  36% /home
/dev/sda6       5,6G   46M    5,3G   1% /tmp
/dev/sda5       5,5G  4,1G    1,1G  79% /var
/dev/sda2       1,9G  137M    1,6G   8% /boot
How can I free up more space?
Thank you for your time
The problem can be solved removing some of the heaviest but safe to remove files in /var
Personally I went with /var/log and /var/cache through the use of rm, example:
sudo rm /var/log/* -r
Now there is enough space in /var to continue with the update
