I purchased a new Laser Jet pro MPF 148fdw specifically because HP is supposed to be Linux friendly. I loaded the driver (https://developers.hp.com/hp-linux-imaging-and-printing/gethplip) Uubuntu 18.04 sees the printer as wireless and can print. It also recognizes it as a fax but not a scanner. Simple Scan can see it but can not scan. (scan works fine on two windows systems) I see some bug reports on line that I do not understand. Probing with my system I several errors that imply the plug in is not loaded, yet it prints. See below. Any ideas on this?
/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py:127: RuntimeWarning: PyOS_InputHook is not available for interactive use of PyGTK
set_interactive(1)
error: Failed to install Plug-in.
Either you have chosen to skip the Plug-in installation or entered incorrect Password.
Checking Permissions....
Checking for Configured Queues....
warning: Device Canon-MX860-series is not HPLIP installed. Device must use the hp: or hpfax: to function in HPLIP.
warning: Canon-MX860-series is not HP Device.
unknown protocol device_uri=ipps://NPI966F14.local:631/ipp/print
Queue(s) configured correctly using HPLIP.
Checking for HP Properitery Plugin's....
No plug-in printers are configured.
Diagnose completed...
More information on Troubleshooting,How-To's and Support is available on http://hplipopensource.com/hplip-web/index.html
Please close this terminal manually.
Diagnose Plugin Utility ver. 1.0
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Segmentation fault
Done.
HP Linux Imaging and Printing System (ver. 3.20.3)
HP Device Manager ver. 15.0
\# Option ā-eā is deprecated and might be removed in a later version of gnome-terminal.
# Use ā-- ā to terminate the options and put the command line to execute after it.
