I'm trying to install Ubuntu 20.04 LTS alongside windows 10 and using unetbootin. When i boot on the unetbootin and choose install ubuntu the screen gets stuck on checking disks: 20% complete while checking the file ./pool/main/libx/libxcrypt/libcrypt1_4.4.10-10ubuntu4_i386.deb
Asked
Active
Viewed 9,389 times
Filesystem Check
At about 20% through the file check, Boot starts checking the file filesystem.squashfs, which takes up about 90% of the ISO and contains most of the OS files. This may take awhile. You can either give it time or remove filesystem checking See: Disable Ubuntu 20.04 disk checkup every boot?
If you press the ESC key you should see what is happening behind the splash screen.
If the persistence file/partition is full it may not proceed beyond this point until all files in casper-rw are deleted.
C.S.Cameron
- 20,530
- 12
- 78
- 125
