Boot hangs for 30 seconds at "Begin: Running /scripts/local-premount"
Try the following:
open /etc/initramfs-tools/conf.d/resume
replace RESUME=UUID=xxx with RESUME=none
issue sudo update-initramfs -u
reboot your system
but in mine
android@inspi:/etc$ cat /etc/initramfs-tools/conf.d/resume
cat: /etc/initramfs-tools/conf.d/resume: No such file or directory
/etc/initramfs-tools/initramfs.conf
android@inspi:/etc$ cat /etc/initramfs-tools/initramfs.conf
# initramfs.conf
# Configuration file for mkinitramfs(8). See initramfs.conf(5).
# Note that configuration options from this file can be overridden
# by config files in the /etc/initramfs-tools/conf.d directory.
# MODULES: [ most | netboot | dep | list ]
# most - Add most filesystem and all harddrive drivers.
# dep - Try and guess which modules to load.
# netboot - Add the base modules, network modules, but skip block devices.
# list - Only include modules from the 'additional modules' list
MODULES=most
# BUSYBOX: [ y | n | auto ]
# Use busybox shell and utilities. If set to n, klibc utilities will be used.
# If set to auto (or unset), busybox will be used if installed and klibc will
# be used otherwise.
BUSYBOX=auto
# COMPCACHE_SIZE: [ "x K" | "x M" | "x G" | "x %" ]
# Amount of RAM to use for RAM-based compressed swap space.
# An empty value - compcache isn't used, or added to the initramfs at all.
# An integer and K (e.g. 65536 K) - use a number of kilobytes.
# An integer and M (e.g. 256 M) - use a number of megabytes.
# An integer and G (e.g. 1 G) - use a number of gigabytes.
# An integer and % (e.g. 50 %) - use a percentage of the amount of RAM.
# You can optionally install the compcache package to configure this setting
# via debconf and have userspace scripts to load and unload compcache.
COMPCACHE_SIZE=""
# COMPRESS: [ gzip | bzip2 | lz4 | lzma | lzop | xz ]
COMPRESS=lz4
# NFS Section of the config.
# DEVICE: ...
# Specify a specific network interface, like eth0
# Overridden by optional ip= or BOOTIF= bootarg
DEVICE=
# NFSROOT: [ auto | HOST:MOUNT ]
NFSROOT=auto
# RUNSIZE: ...
# The size of the /run tmpfs mount point, like 256M or 10%
# Overridden by optional initramfs.runsize= bootarg
RUNSIZE=10%
