I am thinking about buying the ASUS ZenBook 14. It features a fancy kind of trackpad, which has extra virtual buttons integrated into it.
I am thinking about installing the Ubuntu 20.04 LTS on it.
Do you know if Ubuntu supports this hardware?
How can I find out about this?
zx485
  • 2,865
Integrated numpad to touchpad is, unfortunately, still not working on Ubuntu 20.04 by default. (reported issue)
But I'm a developer and I've written a linux driver that enables most of the features. Download and configure for your device and it should work perfectly.
Edit: Unfortunately, as a fellow user suggested, you will need an additional driver for the numpad on the touchpad to work.
I believe their trackpad is just a fancy way of enabling NumLock, so if it doesn't need any extra driver, (is plug-n-play), the trackpad shouldn't be a problem.
However, you may need to install Nvidia drivers.
If you want to make sure it is compatible you should delve into reviews and technical documentation. I would personally check if it's plug n play or if it requires extra software, as soon as it requires extra software, it will be incompatible with other OS.
Santiago
  • 189
