All the DKMS-managed kernel modules started to fail during loading on my Ubuntu 18.04 machine. I noticed it with acpi_call so let me use that to demonstrate:
# uname -r
4.15.0-99-generic
# modinfo acpi_call.ko
filename:       /lib/modules/4.15.0-99-generic/updates/dkms/acpi_call.ko
license:        GPL
srcversion:     72B6FB9451F0D2139482F11
depends:
retpoline:      Y
vermagic:       4.15.0-99-generic SMP mod_unload
signat:         PKCS#7
signer:
sig_key:
sig_hashalgo:   md4
# modprobe acpi_call
modprobe: ERROR: could not insert 'acpi_call': Exec format error
I have tried reinstalling it with DKMS, to no avail:
# dkms status acpi-call
acpi-call, 1.1.0, 4.15.0-99-generic, x86_64: installed
# dkms remove acpi-call/1.1.0 --all
-------- Uninstall Beginning --------
Module:  acpi-call
Version: 1.1.0
Kernel:  4.15.0-99-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
acpi_call.ko:
 - Uninstallation
   - Deleting from: /lib/modules/4.15.0-99-generic/updates/dkms/
 - Original module
   - No original module was found for this module on this kernel.
   - Use the dkms install command to reinstall any previous module version.
depmod...
DKMS: uninstall completed.
Deleting module version: 1.1.0
completely from the DKMS tree.
Done.
# dkms install acpi-call/1.1.0
Creating symlink /var/lib/dkms/acpi-call/1.1.0/source ->
                 /usr/src/acpi-call-1.1.0
DKMS: add completed.
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
cleaning build area...
make -j8 KERNELRELEASE=4.15.0-99-generic -C /lib/modules/4.15.0-99-generic/build M=/var/lib/dkms/acpi-call/1.1.0/build...
Signing module:
 - /var/lib/dkms/acpi-call/1.1.0/4.15.0-99-generic/x86_64/module/acpi_call.ko
Nothing to do.
DKMS: build completed.
acpi_call.ko:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/4.15.0-99-generic/updates/dkms/
depmod...
DKMS: install completed.
Other modules in /lib/modules/4.15.0-99-generic/updates/dkms exhibit the exact same problem.
I have also tried modprobe -f, leading to a different error message:
# modprobe -f acpi_call
modprobe: ERROR: could not insert 'acpi_call': Required key not available
This led me down the MOK rabbit hole but even after enrolling a new MOK and sign-file-ing the .ko files, I am still getting the Required key not available error. If I disable validation, then modprobe -f still fails with Exec format error.
Also, I have noticed this line in dmesg:
[  617.320431] module: x86/modules: Skipping invalid relocation target, existing value is nonzero for type 1, loc 0000000057734886, val ffffffffc0d56a43
What is going wrong here and how do I fix it?
