My Ubuntu is within a virtual machine.
When I log in with a Ubuntu session, the web browser works fine. But when I log in with an Xfce session, the web browser does not work… I try to change proxy setting, it gives me:
When running Google Chrome under a supported desktop environment, the system proxy settings will be used. However, either your system is not supported or there was a problem launching your system configuration.
But you can still configure via the command line. Please see man google-chrome for more information on flags and environment variables.
Could anyone help?
SoftTimur
  • 3,089
Solution 1
There's a command line option --proxy-server - so it should be possible to run chrome using a terminal window, using the command
google-chrome --proxy-server="<proxy-name>:<proxy-port>"
Solution 2
Another solution would be to set the environment variables:
http_proxy=<proxy-name>:<proxy-port>
https_proxy=<proxy-name>:<proxy-port>
export http_proxy
export https_proxy
google-chrome
tohuwawohu
  • 7,502
