I set up a Fedora VM using GNOME Boxes. I can launch it, everything's OK.
I'm using virt-manager and I want to create a bridge so that I can get the VM on the network, but every time I attempt switching the NIC mode from usermode networking to specify shared device name an error is returned.
I do have virbr0 and virbr0-nic up.
The error is:
Error starting domain: internal error: /usr/lib/qemu/qemu-bridge-helper --use-vnet --br=virbr0 --fd=26: failed to communicate with bridge helper: Transport endpoint is not connected
stderr=failed to parse default acl file `/etc/qemu/bridge.conf
Traceback (most recent call last):
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 89, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 125, in tmpcb
callback(*args, **kwargs)
File "/usr/share/virt-manager/virtManager/libvirtobject.py", line 82, in newfn
ret = fn(self, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/domain.py", line 1508, in startup
self._backend.create()
File "/usr/lib/python2.7/dist-packages/libvirt.py", line 1062, in create
if ret == -1: raise libvirtError ('virDomainCreate() failed', dom=self)
libvirtError: internal error: /usr/lib/qemu/qemu-bridge-helper --use-vnet --br=virbr0 --fd=26: failed to communicate with bridge helper: Transport endpoint is not connected
stderr=failed to parse default acl file `/etc/qemu/bridge.conf'
