I recently assembled a new desktop with an ASUS PCE-N15 wireless network adapter and my home wireless network is detected and I am able to connect to it and even access the Internet.
However, after little time I lose the Internet connection, not the wireless connection to the home network, and have to manually disconnect and reconnect in order to get Internet working.
Anyone has any ideas?
UPDATE: /var/log/messages
Apr 19 13:46:50 videl kernel: [13415.875472] rtl8192c: Loading firmware file rtlwifi/rtl8192cfw.bin
Apr 19 13:58:08 videl kernel: [14093.833899] cfg80211: Calling CRDA to update world regulatory domain
Apr 19 13:58:08 videl kernel: [14093.913925] cfg80211: World regulatory domain updated:
Apr 19 13:58:08 videl kernel: [14093.913926] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Apr 19 13:58:08 videl kernel: [14093.913927] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Apr 19 13:58:08 videl kernel: [14093.913929] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Apr 19 13:58:08 videl kernel: [14093.913930] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Apr 19 13:58:08 videl kernel: [14093.913932] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Apr 19 13:58:08 videl kernel: [14093.913933] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Apr 19 13:58:13 videl kernel: [14098.456988] rtl8192c: Loading firmware file rtlwifi/rtl8192cfw.bin
UPDATE 2: The result of running ip route list with and without internet connection is the same:
default via 192.168.1.1 dev wlan0  proto static
169.254.0.0/16 dev wlan0  scope link  metric 1000
192.168.1.0/24 dev wlan0  proto kernel  scope link  src 192.168.1.7  metric 2
Ivo
  • 13
It's the same driver (rtl8192ce) as in this question - and a very similar behaviour. Best solution up to now is to use kernel 3.0.0-14. It's not perfect but better than any of the later kernels.
Thomas
  • 1,666
