I've seen Mount vmdk disk ubuntu? and How to mount a virtual hard disk? as well as How to convert vmdk to bootable Disk or usb but I'm still having some problems.
I had a 32GB sd card. I went, in lubuntu, to system-tools gparted and made a partition of 2GB, under Linux File system. Here's my output for sudo fdisk -l:
Disk /dev/loop0: 1 GiB, 1115181056 bytes, 2178088 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 774.1 MiB, 811728896 bytes, 1585408 sectors
Disk /dev/sda: 3.8 GiB, 4022337024 bytes, 7856127 sectors
Disklabel type: dos
Disk identifier: 0x59fdf6ce
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 38 7839719 7839682 3.8G b W95 FAT32
/dev/sda2 7839744 7854079 14336 7M 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 29.7 GiB, 31914983424 bytes, 62333952 sectors
Disklabel type: dos
Disk identifier: 0x7d0ee0dd
/dev/sdb1 2048 58241023 58238976 27.8G c W95 FAT32 (LBA)
/dev/sdb2 58241024 62332927 4091904 2G 83 Linux
Disk /dev/zram0: 470 MiB, 492838912 bytes, 120322 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/zram1: 470 MiB, 492838912 bytes, 120322 sectors
Disk /dev/zram2: 470 MiB, 492838912 bytes, 120322 sectors
Disk /dev/zram3: 470 MiB, 492838912 bytes, 120322 sectors
And here is my system info (just to be complete):
sudo lshw -short
H/W path Device Class Description
system Inspiron N5040 (To be fill
/0 bus 0R08PM
/0/4 processor Intel(R) Core(TM) i3 CPU
/0/4/5 memory 64KiB L1 cache
/0/4/6 memory 512KiB L2 cache
/0/4/7 memory 3MiB L3 cache
/0/4/1.1 processor Logical CPU
/0/4/1.2 processor Logical CPU
/0/4/1.3 processor Logical CPU
/0/4/1.4 processor Logical CPU
/0/4/1.5 processor Logical CPU
/0/4/1.6 processor Logical CPU
/0/4/1.7 processor Logical CPU
/0/4/1.8 processor Logical CPU
/0/4/1.9 processor Logical CPU
/0/4/1.a processor Logical CPU
/0/4/1.b processor Logical CPU
/0/4/1.c processor Logical CPU
/0/4/1.d processor Logical CPU
/0/4/1.e processor Logical CPU
/0/4/1.f processor Logical CPU
/0/4/1.10 processor Logical CPU
/0/14 memory 4GiB System Memory
/0/14/0 memory 4GiB DIMM DDR3 Synchronous
/0/14/1 memory DIMM [empty]
/0/0 memory 64KiB BIOS
/0/1 processor
/0/1/1.1 processor Logical CPU
/0/1/1.2 processor Logical CPU
/0/1/1.3 processor Logical CPU
/0/1/1.4 processor Logical CPU
/0/1/1.5 processor Logical CPU
/0/1/1.6 processor Logical CPU
/0/1/1.7 processor Logical CPU
/0/1/1.8 processor Logical CPU
/0/1/1.9 processor Logical CPU
/0/1/1.a processor Logical CPU
/0/1/1.b processor Logical CPU
/0/1/1.c processor Logical CPU
/0/1/1.d processor Logical CPU
/0/1/1.e processor Logical CPU
/0/1/1.f processor Logical CPU
/0/1/1.10 processor Logical CPU
/0/100 bridge Core Processor DRAM Contro
/0/100/2 display Core Processor Integrated
/0/100/16 communication 5 Series/3400 Series Chips
/0/100/1a bus 5 Series/3400 Series Chips
/0/100/1a/1 usb1 bus EHCI Host Controller
/0/100/1a/1/1 bus Integrated Rate Matching H
/0/100/1a/1/1/3 scsi7 storage USB2.0-CRW
/0/100/1a/1/1/3/0.0.0 /dev/sdb disk 31GB Multi-Card
/0/100/1a/1/1/3/0.0.0/0 /dev/sdb disk 31GB
/0/100/1a/1/1/3/0.0.0/0/1 /dev/sdb1 volume 27GiB Windows FAT volume
/0/100/1a/1/1/3/0.0.0/0/2 /dev/sdb2 volume 1998MiB EXT4 volume
/0/100/1a/1/1/4 multimedia Integrated Webcam
/0/100/1b multimedia 5 Series/3400 Series Chips
/0/100/1c bridge 5 Series/3400 Series Chips
/0/100/1c.1 bridge 5 Series/3400 Series Chips
/0/100/1c.1/0 wlp18s0b1 network BCM4313 802.11bgn Wireless
/0/100/1c.2 bridge 5 Series/3400 Series Chips
/0/100/1c.2/0 enp19s0 network RTL810xE PCI Express Fast
/0/100/1c.4 bridge 5 Series/3400 Series Chips
/0/100/1d bus 5 Series/3400 Series Chips
/0/100/1d/1 usb2 bus EHCI Host Controller
/0/100/1d/1/1 bus Integrated Rate Matching H
/0/100/1d/1/1/4 scsi6 storage SanDisk Cruzer
/0/100/1d/1/1/4/0.0.0 /dev/sda disk 4022MB SanDisk Cruzer
/0/100/1d/1/1/4/0.0.0/0 /dev/sda disk 4022MB
/0/100/1d/1/1/4/0.0.0/0/1 /dev/sda1 volume 3827MiB Windows FAT volume
/0/100/1d/1/1/4/0.0.0/0/2 /dev/sda2 volume 15EiB Windows NTFS volume
/0/100/1e bridge 82801 Mobile PCI Bridge
/0/100/1f bridge HM57 Chipset LPC Interface
/0/100/1f.2 storage 5 Series/3400 Series Chips
/0/100/1f.3 bus 5 Series/3400 Series Chips
/0/100/1f.6 generic 5 Series/3400 Series Chips
/0/101 bridge Core Processor QuickPath A
/0/102 bridge Core Processor QuickPath A
/0/103 bridge Core Processor QPI Link 0
/0/104 bridge 1st Generation Core i3/5/7
/0/105 bridge 1st Generation Core i3/5/7
/0/106 bridge 1st Generation Core i3/5/7
/0/2 scsi1 storage
/0/2/0.0.0 /dev/cdrom disk DVD+-RW DS-8A8SH
/1 power DELL W7H3N06
And CPU info:
sudo lscpu
Architecture: i686
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 2
Core(s) per socket: 2
Socket(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 37
Model name: Intel(R) Core(TM) i3 CPU M 390 @ 2.67GHz
Stepping: 5
CPU MHz: 1642.128
CPU max MHz: 2660.0000
CPU min MHz: 931.0000
BogoMIPS: 5319.85
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 3072K
Basically I'm trying to mount a vsdk android x86 file (originally downlaoded as a .vdi and converted with virtualbox)
I saw an answer that suggested using the following commands:
sudo modprobe nbd
sudo qemu-nbd -r -c /dev/nbd1 ./linux_box/VM/image.vmdk
mount /dev/nbd1p1 /mnt
However when I run the second one (sudo qemu-nbd -r -c /dev/nbd2 ./ok.vmdk, after running sudo apt-get install update and sudo apt-getinstall qemu-utils), followed by sudo mount /dev/nbd2 /mnt, I get:
mount: /mnt: wrong fs type, bad option, bad superblock on /dev/nbd2, missing codepage or helper program, or other error.
I'm not sure what I'm doing wrong, I set the partition earlier as ext4 (you can see it in the first output), I don't know what other file system to put?
