I have Amazon AWS running Ubuntu 18.04, I need to install Lets encrypt, so I tried following commands, when I install python3-certbot-apache it gives error of unmet dependencies. Can you please help me
I have run following command:
  • sudo apt-get update sudo apt-get install software-properties-common
  • sudo add-apt-repository universe
  • sudo add-apt-repository ppa:certbot/certbot
  • sudo apt-get install python3-certbot-apache -- This command failed
I have given here the commands and output
sudo apt-get update
Hit:1 http://ppa.launchpad.net/certbot/certbot/ubuntu bionic InRelease
Hit:2 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://ppa.launchpad.net/ondrej/php/ubuntu bionic InRelease
Reading package lists... Done
Building dependency tree
software-properties-common is already the newest version (0.96.24.32.12).
0 upgraded, 0 newly installed, 0 to remove and 47 not upgraded.
'universe' distribution component is already enabled for all sources.
 This is the PPA for packages prepared by Debian Let's Encrypt Team and backported for Ubuntu.
Note: Packages are only provided for currently supported Ubuntu releases.
More info: https://launchpad.net/~certbot/+archive/ubuntu/certbot
Press [ENTER] to continue or Ctrl-c to cancel adding it.
 python3-certbot-apache :
 - Depends: certbot (>= 0.26.0~) but it is not going to be installed
 - Depends: python3-acme (>= 0.25.0~) but it is not going to be installed
 - Depends: python3-augeas but it is not going to be installed
 - Depends: python3-certbot (>= 0.26.0~) but it is not going to be installed
 - Depends: python3-mock but it is not going to be installed
kram
As per suggestion given in
https://community.letsencrypt.org/t/installing-certbot-on-ubuntu-18-04-problems/68778/5
I have changed /etc/apt/source.list first line as follows:
After this change run apt-get update, then able to install the package and Certbot.
kram
