-1
when i run
sudo apt install build-essential zlib1g-dev libncurses5-dev libgdbm-dev libnss3-dev libssl-dev libreadline-dev libffi-dev libsqlite3-dev wget libbz2-dev -y && wget https://www.python.org/ftp/python/3.8.2/Python-3.8.2.tgz && tar -xf Python-3.8.2.tgz && cd Python-3.8.2 && ./configure --enable-optimizations && make -j 8 && sudo make altinstall
the output is :
Reading package lists... Done
Building dependency tree
build-essential is already the newest version (12.4ubuntu1).
wget is already the newest version (1.19.4-1ubuntu2.2).
 libssl-dev : Depends: libssl1.1 (= 1.1.1-1ubuntu2.1~18.04.5) but 1.1.1c-1+ubuntu18.04.1+deb.sury.org+1 is to be installed
Have you tried to update your system first?
sudo apt-get update && apt-get upgrade
If you have "kept-back" packages I would refer you to this post
