I am trying to install ms sql in Ubuntu 20.04. Even I have got it installed in 20.04 successfully following this guide but I sometime I have this problem multiple time and not sure why is this happening.
When I try to run following commads
curl https://packages.microsoft.com/config/ubuntu/18.04/prod.list | sudo tee /etc/apt/sources.list.d/msprod.list
sudo apt-get install mssql-tools unixodbc-dev
I end up having below errors:
mssql-tools : Depends: msodbcsql17 (>= 17.3.0.0) but it is not going to be installed
unixodbc-dev : Depends: unixodbc (= 2.3.7)
Depends: odbcinst1debian2 (= 2.3.7) but 2.3.6-0.1build1 is to be inst
sudo apt-cache policy <package> shows multiple versions available for these packages.
I tried installing the right versions for dependencies that did not help when I ran sudo apt-get install mssql-tools unixodbc-dev again.
When I checked msprod.list file, it looks like 'https://packages.microsoft.com/config/ubuntu/18.04/prod' the tailed .list is missing so I added that(not sure I should do that or not). Then I have got everything installed.
Now when I do sudo apt update it ends up with below error:
E: The repository 'https://packages.microsoft.com/ubuntu/18.04/prod.list bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I really don't understand what is happening and what I have to do to get thing working in simplest way.
