I am not able to install a package using apt due to the following error:
Reading package lists...
Building dependency tree...
Reading state information...
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
134 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up python3 (3.8.2-0ubuntu2) ...
running python rtupdate hooks for python3.8...
dpkg-query: package 'rhythmbox-plugin-alternative-toolbar' is not installed
Use dpkg --contents (= dpkg-deb --contents) to list archive files contents.
Traceback (most recent call last):
File "/usr/bin/py3clean", line 210, in <module>
main()
File "/usr/bin/py3clean", line 196, in main
pfiles = set(dpf.from_package(options.package))
File "/usr/share/python3/debpython/files.py", line 53, in from_package
raise Exception("cannot get content of %s" % package_name)
Exception: cannot get content of rhythmbox-plugin-alternative-toolbar
error running python rtupdate hook rhythmbox-plugin-alternative-toolbar
dpkg-query: package 'rhythmbox-plugins' is not installed
main()
Exception: cannot get content of rhythmbox-plugins
error running python rtupdate hook rhythmbox-plugins
dpkg-query: package 'ubuntu-drivers-common' is not installed
main()
Exception: cannot get content of ubuntu-drivers-common
error running python rtupdate hook ubuntu-drivers-common
dpkg: error processing package python3 (--configure):
installed python3 package post-installation script subprocess returned error exit status 4
dpkg: dependency problems prevent configuration of apport:
apport depends on python3; however:
Package python3 is not configured yet.
dpkg: error processing package apport (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of python3-tz:
python3-tz depends on python3:any; however:
dpkg: error processing package python3-tz (--configure):
dpkg: dependency problems prevent configuration of python3-apport:
python3-apport depends on python3:any (>= 3.0~); however:
dpkg: error processing package python3-apport (--configure):
dpkg: dependency problems prevent configuration of python3-cupshelpers:
python3-cupshelpers depends on python3:any; however:
dpkg: error processing package python3-cupshelpers (--configure):
dpkg: dependency problems prevent configuration of python3-requests-unixsocket:
python3-requests-unixsocket depends on python3:any; however:
dpkg: error processing package python3-requests-unixsocket (--configure):
dpkg: dependency problems prevent configuration of python3-six:
python3-six depends on python3:any; however:
dpkg: error processing package python3-six (--configure):
dpkg: dependency problems prevent configuration of python3-simplejson:
python3-simplejson depends on python3 (<< 3.9); however:
python3-simplejson depends on python3 (>= 3.8~); however:
python3-simplejson depends on python3:any; however:
dpkg: error processing package python3-simplejson (--configure):
dpkg: dependency problems prevent configuration of ibus-table:
ibus-table depends on python3:any; however:
dpkg: error processing package ibus-table (--configure):
dpkg: dependency problems prevent configuration of python3-cups:
python3-cups depends on python3 (<< 3.9); however:
python3-cups depends on python3 (>= 3.8~); however:
dpkg: error processing package python3-cups (--configure):
dpkg: dependency problems prevent configuration of python3-oauthlib:
python3-oauthlib depends on python3:any; however:
dpkg: error processing package python3-oauthlib (--configure):
dpkg: dependency problems prevent configuration of python3-chardet:
python3-chardet depends on python3:any; however:
dpkg: error processing package python3-chardet (--configure):
dpkg: dependency problems prevent configuration of python3-secretstorage:
python3-secretstorage depends on python3:any; however:
dpkg: error processing package python3-secretstorage (--configure):
dpkg: dependency problems prevent configuration of system-config-printer:
system-config-printer depends on python3-cups (>= 1.9.60); however:
Package python3-cups is not configured yet.
system-config-printer depends on python3-cupshelpers (= 1.5.12-0ubuntu1); however:
Package python3-cupshelpers is not configured yet.
system-config-printer depends on python3:any; however:
dpkg: error processing package system-config-printer (--configure):
dpkg: dependency problems prevent configuration of python3-certifi:
python3-certifi depends on python3:any; however:
dpkg: error processing package python3-certifi (--configure):
dpkg: dependency problems prevent configuration of python3-cryptography:
python3-cryptography depends on python3 (>= 3~); however:
python3-cryptography depends on python3-six (>= 1.4.1); however:
Package python3-six is not configured yet.
python3-cryptography depends on python3:any; however:
dpkg: error processing package python3-cryptography (--configure):
dpkg: dependency problems prevent configuration of python3-wadllib:
python3-wadllib depends on python3:any; however:
dpkg: error processing package python3-wadllib (--configure):
dpkg: dependency problems prevent configuration of python3-debian:
python3-debian depends on python3-chardet; however:
Package python3-chardet is not configured yet.
python3-debian depends on python3-six (>> 1.4~); however:
python3-debian depends on python3:any; however:
dpkg: error processing package python3-debian (--configure):
dpkg: dependency problems prevent configuration of python3-gi:
python3-gi depends on python3 (<< 3.9); however:
python3-gi depends on python3 (>= 3.8~); however:
python3-gi depends on python3:any; however:
dpkg: error processing package python3-gi (--configure):
dpkg: dependency problems prevent configuration of python3-requests:
python3-requests depends on python3-certifi; however:
Package python3-certifi is not configured yet.
python3-requests depends on python3-chardet (<< 3.1.0); however:
python3-requests depends on python3:any; however:
python3-requests depends on python3-chardet (>= 3.0.2); however:
dpkg: error processing package python3-requests (--configure):
dpkg: dependency problems prevent configuration of python3-idna:
python3-idna depends on python3:any; however:
dpkg: error processing package python3-idna (--configure):
dpkg: dependency problems prevent configuration of python3-urllib3:
python3-urllib3 depends on python3:any; however:
python3-urllib3 depends on python3-six; however:
dpkg: error processing package python3-urllib3 (--configure):
dpkg: dependency problems prevent configuration of gnome-shell:
gnome-shell depends on python3; however:
dpkg: error processing package gnome-shell (--configure):
dpkg: dependency problems prevent configuration of ubuntu-session:
ubuntu-session depends on gnome-shell (>= 3.36.0-2ubuntu1~); however:
Package gnome-shell is not configured yet.
dpkg: error processing package ubuntu-session (--configure):
dpkg: dependency problems prevent configuration of ibus:
ibus depends on python3:any; however:
ibus depends on python3-gi; however:
Package python3-gi is not configured yet.
dpkg: error processing package ibus (--configure):
dpkg: dependency problems prevent configuration of gdm3:
gdm3 depends on gnome-shell (>= 3.19.92); however:
dpkg: error processing package gdm3 (--configure):
dpkg: dependency problems prevent configuration of python3-defer:
python3-defer depends on python3:any (>= 3.2~); however:
dpkg: error processing package python3-defer (--configure):
dpkg: dependency problems prevent configuration of python3-keyring:
python3-keyring depends on python3-secretstorage; however:
Package python3-secretstorage is not configured yet.
python3-keyring depends on python3:any; however:
dpkg: error processing package python3-keyring (--configure):
dpkg: dependency problems prevent configuration of python3-httplib2:
python3-httplib2 depends on python3:any; however:
dpkg: error processing package python3-httplib2 (--configure):
dpkg: dependency problems prevent configuration of language-selector-common:
language-selector-common depends on python3:any; however:
dpkg: error processing package language-selector-common (--configure):
dpkg: dependency problems prevent configuration of lsb-release:
lsb-release depends on python3:any; however:
dpkg: error processing package lsb-release (--configure):
dpkg: dependency problems prevent configuration of python3-protobuf:
python3-protobuf depends on python3 (<< 3.9); however:
python3-protobuf depends on python3 (>= 3.8~); however:
python3-protobuf depends on python3-six (>= 1.9); however:
python3-protobuf depends on python3:any; however:
dpkg: error processing package python3-protobuf (--configure):
dpkg: dependency problems prevent configuration of python3-rfc3339:
python3-rfc3339 depends on python3-tz; however:
Package python3-tz is not configured yet.
python3-rfc3339 depends on python3:any; however:
dpkg: error processing package python3-rfc3339 (--configure):
dpkg: dependency problems prevent configuration of python3-macaroonbakery:
python3-macaroonbakery depends on python3-protobuf (>= 3.0.0); however:
Package python3-protobuf is not configured yet.
python3-macaroonbakery depends on python3-requests (>= 2.18.1); however:
Package python3-requests is not configured yet.
python3-macaroonbakery depends on python3-rfc3339 (>= 1.0); however:
Package python3-rfc3339 is not configured yet.
python3-macaroonbakery depends on python3-six (<< 2.0); however:
python3-macaroonbakery depends on python3-six (>= 1.11.0); however:
python3-macaroonbakery depends on python3:any; however:
dpkg: error processing package python3-macaroonbakery (--configure):
dpkg: dependency problems prevent configuration of python3-aptdaemon.gtk3widgets:
python3-aptdaemon.gtk3widgets depends on python3:any (>= 3.2~); however:
python3-aptdaemon.gtk3widgets depends on python3-gi; however:
dpkg: error processing package python3-aptdaemon.gtk3widgets (--configure):
dpkg: dependency problems prevent configuration of python3-ibus-1.0:
python3-ibus-1.0 depends on python3:any; however:
python3-ibus-1.0 depends on python3-gi (>= 3.8); however:
dpkg: error processing package python3-ibus-1.0 (--configure):
dpkg: dependency problems prevent configuration of python3-lazr.restfulclient:
python3-lazr.restfulclient depends on python3-httplib2 (>= 0.7.7); however:
Package python3-httplib2 is not configured yet.
python3-lazr.restfulclient depends on python3-simplejson; however:
Package python3-simplejson is not configured yet.
python3-lazr.restfulclient depends on python3-wadllib (>= 1.1.4); however:
Package python3-wadllib is not configured yet.
python3-lazr.restfulclient depends on python3-oauthlib; however:
Package python3-oauthlib is not configured yet.
python3-lazr.restfulclient depends on python3-six; however:
python3-lazr.restfulclient depends on python3:any; however:
dpkg: error processing package python3-lazr.restfulclient (--configure):
dpkg: dependency problems prevent configuration of python3-gi-cairo:
python3-gi-cairo depends on python3-gi (= 3.36.0-1); however:
python3-gi-cairo depends on python3 (<< 3.9); however:
python3-gi-cairo depends on python3 (>= 3.8~); however:
dpkg: error processing package python3-gi-cairo (--configure):
dpkg: dependency problems prevent configuration of python3-nacl:
python3-nacl depends on python3 (>= 3~); however:
python3-nacl depends on python3-six; however:
python3-nacl depends on python3:any; however:
dpkg: error processing package python3-nacl (--configure):
dpkg: dependency problems prevent configuration of python3-systemd:
python3-systemd depends on python3 (<< 3.9); however:
python3-systemd depends on python3 (>= 3.8~); however:
python3-systemd depends on python3:any; however:
dpkg: error processing package python3-systemd (--configure):
dpkg: dependency problems prevent configuration of python3-cffi-backend:
python3-cffi-backend depends on python3 (<< 3.9); however:
python3-cffi-backend depends on python3 (>= 3.8~); however:
dpkg: error processing package python3-cffi-backend (--configure):
dpkg: dependency problems prevent configuration of zoom:
zoom depends on ibus; however:
Package ibus is not configured yet.
dpkg: error processing package zoom (--configure):
dpkg: dependency problems prevent configuration of python3-blinker:
python3-blinker depends on python3:any; however:
dpkg: error processing package python3-blinker (--configure):
dpkg: dependency problems prevent configuration of python3-pkg-resources:
python3-pkg-resources depends on python3:any; however:
dpkg: error processing package python3-pkg-resources (--configure):
dpkg: dependency problems prevent configuration of python3-entrypoints:
python3-entrypoints depends on python3:any; however:
dpkg: error processing package python3-entrypoints (--configure):
dpkg: dependency problems prevent configuration of networkd-dispatcher:
networkd-dispatcher depends on python3-gi; however:
networkd-dispatcher depends on python3:any; however:
dpkg: error processing package networkd-dispatcher (--configure):
dpkg: dependency problems prevent configuration of language-selector-gnome:
language-selector-gnome depends on language-selector-common (= 0.204); however:
Package language-selector-common is not configured yet.
language-selector-gnome depends on python3:any; however:
language-selector-gnome depends on python3-gi; however:
language-selector-gnome depends on python3-aptdaemon.gtk3widgets; however:
Package python3-aptdaemon.gtk3widgets is not configured yet.
dpkg: error processing package language-selector-gnome (--configure):
dpkg: dependency problems prevent configuration of gedit-common:
gedit-common depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package gedit-common (--configure):
dpkg: dependency problems prevent configuration of python3-dbus:
python3-dbus depends on python3 (<< 3.9); however:
python3-dbus depends on python3 (>= 3.8~); however:
python3-dbus depends on python3:any; however:
dpkg: error processing package python3-dbus (--configure):
dpkg: dependency problems prevent configuration of system-config-printer-common:
system-config-printer-common depends on python3-cups (>= 1.9.60); however:
system-config-printer-common depends on python3-cupshelpers (= 1.5.12-0ubuntu1); however:
system-config-printer-common depends on python3-dbus; however:
Package python3-dbus is not configured yet.
system-config-printer-common depends on python3-gi; however:
system-config-printer-common depends on python3-requests; however:
system-config-printer-common depends on python3:any; however:
dpkg: error processing package system-config-printer-common (--configure):
dpkg: too many errors, stopping
python3
apport
python3-tz
python3-apport
python3-cupshelpers
python3-six
python3-simplejson
ibus-table
python3-cups
python3-oauthlib
python3-chardet
python3-certifi
python3-wadllib
python3-debian
python3-gi
python3-requests
python3-idna
python3-urllib3
gnome-shell
ubuntu-session
ibus
gdm3
python3-defer
python3-keyring
python3-httplib2
lsb-release
python3-protobuf
python3-rfc3339
python3-ibus-1.0
python3-gi-cairo
python3-nacl
python3-systemd
zoom
python3-blinker
python3-entrypoints
networkd-dispatcher
gedit-common
python3-dbus
Processing was halted because there were too many errors.
So I tried to fix the issue by running:
sudo apt --fix-broken install
But the same error happened.
I upgraded my Ubuntu from 19.10 to 20.04. And Suddenly Ubuntu lost the database of apt packages and didn't recognize the packages that are already installed.
Does anyone face the same issue and have a solution to this?
Many thanks!
