I recently installed Ubuntu 20.04 dual-boot alongside pre-installed Windows 10 on my laptop (on the same SSD disk, but separate partitions) with a UEFI boot loader.
now I can not write, create or edit anything on my NTFS HDD partitions. I've searched for the problem and tested the below configuration for the mount point in /etc/fstab but unfortunately, it doesn't work.
LABEL=Learnings /mnt/Learnings ntfs rw,exec,users,umask=000,dmask=000,fmask=000,uid=1000,gid=1000,x-gvfs-show 0 0
this is the ls -l command result on an NTFS partition which denotes I have the right access to files and folders.
-rwxrwxrwx 1 mohsen mohsen 78 Feb 16 21:30 /mnt/Learnings/Note.txt
drwxrwxrwx 1 mohsen mohsen 0 Apr 23 21:56 /mnt/Learnings/TEMP
also, it should be noted that:
- I've disabled the hibernation mode in windows 10 with
powercfg.exe /hibernate offcommand. - I'm not sure if it relates, but I've recently twice experienced the blue screen page on Windows while I was backing up the disk and also while I was trying to restart the OS.
Thanks in Advance, Mohsen.
