I have a Raspberry 4 / 4G running Ubuntu, it has a 7” touch Screen connected with a ribbon cable. When Plug a TV or other Monitor into the HDMI port I only get sound. As soon get no options in the settings for the second monitor.
This what I get when I run xrandr with the second monitor plunged in
ubuntu@brad-pi:~$ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 800 x 480, current 800 x 480, maximum 800 x 480
default connected primary 800x480+0+0 0mm x 0mm
   800x480        0.00*
any help or point in the right direction would appreciated
M.A.K. Ripon
  • 3,409
  • 28
  • 36
I have the same configuration as you. (Ubuntu on a raspberry pi with 7" display with a second monitor connected via HDMI cable). The following worked for me.
sudo nano /boot/fireware/usercfg.txt
After the file is open
# Definitely required
dtoverlay=vc4-fkms-v3d
If one of the monitors have dark border
disable_overscan=1
Not sure what it does. Might not be required.
max_framebuffers=2
Save and exit. Install the following
sudo apt install xfce4-settings
Reboot
sudo reboot
After login to check the displays
xfce4-display-settings &
For me, this was displaying two monitors side by side (one huge and another small). To get the name of the displays:
xrandr --current
If it is displaying two different monitors
xrandr --output <projector> --same-as <desktop>
where in my case was HDMI-1 and was DSI-1. To switch off the (DSI-1) monitor
xrandr --output HDMI-1 && xrandr --output DSI-1 --off
This will switch off the DSI-1 monitor.
My references: Ref1, Ref2, Ref3
ASarkar
  • 101
