17
I upgraded Ubuntu from 18.04 to 20.04. I am experiencing very slow boot up times. It takes about 2+ minutes to fully boot up.
I have tried looking for some solutions by myself, but I am not sure on what to do to speed up the start up process.
Here is the log from systemd-analyze:
Startup finished in 5.706s (kernel) + 1min 43.625s (userspace) = 1min 49.331s
graphical.target reached after 1min 43.609s in userspace
Here is the log from systemd-analyze blame:
58.970s mysql.service
57.405s udisks2.service
46.492s plymouth-quit-wait.service
30.941s snapd.service
27.644s networkd-dispatcher.service
25.554s dev-sda6.device
23.983s systemd-journal-flush.service
21.631s accounts-daemon.service
18.247s apache2.service
18.116s dev-loop8.device
17.584s dev-loop13.device
17.547s dev-loop10.device
16.902s dev-loop12.device
16.843s dev-loop11.device
16.838s dev-loop7.device
16.532s dev-loop9.device
16.344s NetworkManager-wait-online.service
15.978s dev-loop6.device
15.870s dev-loop5.device
15.614s ModemManager.service
15.110s dev-loop0.device
13.675s dev-loop1.device
12.752s dev-loop4.device
12.680s dev-loop3.device
12.250s NetworkManager.service
10.742s avahi-daemon.service
10.734s bluetooth.service
10.460s dev-loop2.device
10.402s polkit.service
 9.641s switcheroo-control.service
 9.595s systemd-logind.service
 9.579s thermald.service
 9.565s wpa_supplicant.service
 6.634s systemd-resolved.service
 5.818s systemd-udevd.service
 5.806s gpu-manager.service
 5.065s gdm.service
 5.010s colord.service
 4.633s plymouth-read-write.service
 4.490s apport.service
 4.489s grub-common.service
 4.314s user@1000.service
 4.194s rsyslog.service
 4.178s apparmor.service
 3.929s e2scrub_reap.service
 3.629s systemd-rfkill.service
 2.280s grub-initrd-fallback.service
 1.876s snapd.apparmor.service
 1.754s networking.service
 1.593s fwupd.service
 1.432s upower.service
 1.294s systemd-tmpfiles-setup.service
 1.110s pppd-dns.service
 1.107s systemd-sysusers.service
 1.058s systemd-journald.service
 1.022s systemd-modules-load.service
  913ms snap-core-8935.mount
  856ms snap-core-9066.mount
  855ms systemd-sysctl.service
  806ms packagekit.service
  805ms snap-core18-1668.mount
  789ms keyboard-setup.service
  771ms systemd-timesyncd.service
  693ms snap-core18-1705.mount
  690ms systemd-udev-trigger.service
  682ms nvidia-persistenced.service
  633ms snapd.seeded.service
  631ms openvpn.service
  624ms systemd-tmpfiles-setup-dev.service
  613ms snap-gnome\x2d3\x2d26\x2d1604-92.mount
  598ms systemd-random-seed.service
  589ms ufw.service
  582ms snap-gnome\x2d3\x2d26\x2d1604-98.mount
  570ms dns-clean.service
  520ms snap-gnome\x2d3\x2d28\x2d1804-110.mount
  494ms swapfile.swap
  494ms snap-gnome\x2d3\x2d28\x2d1804-116.mount
  381ms snap-gnome\x2d3\x2d34\x2d1804-27.mount
  368ms plymouth-start.service
  330ms modprobe@drm.service
  314ms kerneloops.service
  266ms snap-gnome\x2dsystem\x2dmonitor-127.mount
  263ms snap-gnome\x2dsystem\x2dmonitor-135.mount
  259ms systemd-remount-fs.service
  250ms phpsessionclean.service
  225ms console-setup.service
  225ms systemd-user-sessions.service
  215ms dev-hugepages.mount
  213ms dev-mqueue.mount
  211ms sys-kernel-debug.mount
  210ms sys-kernel-tracing.mount
  209ms snap-gtk\x2dcommon\x2dthemes-1506.mount
  206ms kmod-static-nodes.service
  197ms snap-snap\x2dstore-433.mount
  187ms setvtrgb.service
  182ms ifupdown-pre.service
  172ms user-runtime-dir@1000.service
  165ms snap-gtk\x2dcommon\x2dthemes-1474.mount
  145ms rtkit-daemon.service
  125ms systemd-update-utmp.service
   35ms ureadahead-stop.service
   22ms alsa-restore.service
   10ms systemd-update-utmp-runlevel.service
    8ms sys-kernel-config.mount
    5ms sys-fs-fuse-connections.mount
    3ms snapd.socket
Here is the log from systemd-analyze critical-chain:
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @1min 43.609s
└─multi-user.target @1min 43.609s
  └─mysql.service @44.637s +58.970s
    └─network.target @44.628s
      └─NetworkManager.service @32.376s +12.250s
        └─dbus.service @32.364s
          └─basic.target @32.122s
            └─sockets.target @32.122s
              └─snapd.socket @32.117s +3ms
                └─sysinit.target @31.803s
                  └─systemd-timesyncd.service @31.031s +771ms
                    └─systemd-tmpfiles-setup.service @29.674s +1.294s
                      └─systemd-journal-flush.service @5.690s +23.983s
                        └─systemd-journald.service @4.629s +1.058s
                          └─systemd-journald.socket @4.620s
                            └─system.slice @4.585s
                              └─-.slice @4.585s
EDIT #1:
Added log from journalctl -b -u udisks2 -u mysql
-- Logs begin at Wed 2020-01-15 17:31:37 EST, end at Wed 2020-04-29 19:09:14 EDT. --
Apr 29 17:06:12 ubuntupet-Inspiron-537 systemd[1]: Starting Disk Manager...
Apr 29 17:06:16 ubuntupet-Inspiron-537 udisksd[806]: udisks daemon version 2.8.4 starting
Apr 29 17:06:24 ubuntupet-Inspiron-537 systemd[1]: Starting MySQL Community Server...
Apr 29 17:06:28 ubuntupet-Inspiron-537 udisksd[806]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
Apr 29 17:06:30 ubuntupet-Inspiron-537 udisksd[806]: Failed to load the 'mdraid' libblockdev plugin
Apr 29 17:07:09 ubuntupet-Inspiron-537 systemd[1]: Started Disk Manager.
Apr 29 17:07:09 ubuntupet-Inspiron-537 udisksd[806]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Apr 29 17:07:21 ubuntupet-Inspiron-537 systemd[1]: Started MySQL Community Server.
I am not sure on how to proceed now.
EDIT #2:
I have uploaded the log from the following command onto Dropbox due to the large amount of lines. journalctl -S "2020-04-29 17:06:30"
Here is the link to the direct log file:
https://www.dropbox.com/s/y8jbtwgc09vddsg/log5.txt?dl=0
It seems that there are a lot of app armor denied errors.
EDIT #3:
I have been unable to find what the cause of the problem is. I have done a clean install of Ubuntu 20.04. The boot up process is down to ~1:20.
GSM-S
  • 624
6 Answers6
As a next step, you may look up the logs of mysql and udisks2, as they seem to take the longest here.
The command journalctl -b -u udisks2 -u mysql should be useful for that.
I'd install Ubuntu 20.04 off the scratch. It looks like your "upgrade" borked something. "systemd-analyze blame" shows exactly, where your time goes... And waiting for mySql for a minute does not make sense at all. My output for udisk2 for example is
406ms udisks2.service
So save your data and install it freshly.
kanehekili
  • 7,426
Had the same problem on an upgraded 20.04 system and never solved it. I since did a fresh reformatted install of 'Groovy Gorilla' 20.10 and boot/shutdown speeds are amazing, the best I have ever seen on any version of Linux or Windows.
mattp
This seemed to help me remove some orphaned packages - https://linoxide.com/linux-how-to/remove-orphaned-packages-ubuntu/. Afterward my shutdowm and startup performance was much better.
-1
I had the same problem and it got fixed when I updated the kernel from 5.4 to 5.9 using Check and Update Ubuntu Kernel Version on Ubuntu 20.04 – Linux Hint
Kulfy
  • 18,154
RXDG14
  1. Check the ownership of /:
    stat /
  2. If you get something like:
    Access: (0755/drwxr-xr-x)  Uid: (1000/ username   Gid: (1000/       username)
    then change the ownership of /:
    chown root:root /
  3. Reboot.
Robert
