I am trying to fix a MiKTeX installation on Ubuntu 18.04, or at least I would like to remove it and all its packages in order to install TexLive.
I tried to install it a couple of weeks ago, following https://miktex.org/howto/install-miktex-unx, and i got
N: Skipping acquire of configured file 'universe/binary-i386/Packages' as repository 'http://miktex.org/download/ubuntu bionic InRelease' doesn't support architecture 'i386'
I didn't have much time to fix the problem, so I didn't do anything. Gong back to it this morning, I tried this solution on the last step:
repository 'http://miktex.org/download/ubuntu xenial InRelease' doesn't support architecture 'i386'
Then I run:
rob@rob-Ubuntu:~$ sudo apt install miktex
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
miktex : Depends: libhunspell-1.3-0 (>= 1.3.3) but it is not installable
Depends: libicu55 (>= 55.1-1~) but it is not installable
Depends: libmpfr4 (>= 3.1.3) but it is not installable
Depends: libpng12-0 (>= 1.2.13-4) but it is not installable
And, at the end
rob@rob-Ubuntu:~$ sudo aptitude install libhunspell-1.3-0
No candidate version found for libhunspell-1.3-0
Unable to apply some actions, aborting
Nothing seems to work.
Any suggestions?
I would like 1- to install Miktex correctly OR 2- cancel anything related to it, and install TexLive.
