What is the minimum size of the home partition and can I use a pre-used NTFS partition as the home partition?
VidathD
  • 2,829
There is no rule as such, of what should be the minimum size of the home partition. You can always consider how much space will/should be allocated to a user, say 2 GB, then the total size of your partition should be the number of user X 2 GB.
Keep in mind that users are restricted to their home only, so all content they create will be in the home only.
About using the existing NTFS part: it is recommended that you use a native Linux FS like ext4 or btrfs, so before using you should format the partition accordingly.
Update your fs tab accordingly.
Ulincsys
  • 786
