Was working fine then stopped inexplicably.
I can ping the gateway/DNS router/firewall (Untangle) using WiFi and cable using WiCd. Network Manager does not work on this computer
Firefox reports "server not found" & pinging google.com gives "unknown host".
WiCd setting show proper DNS IP, /etc/reslov.conf contains the correct IP (it was missing but I replaced it).
The DNS server/gateway (192.168.0.1) works with other computers on the local network.
From laptop (192.168.0.55)…
user@laptop:~$ cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 192.168.0.1
user@laptop:~$ ping 192.168.0.1
PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data.
64 bytes from 192.168.0.1: icmp_req=1 ttl=64 time=0.854 ms
64 bytes from 192.168.0.1: icmp_req=2 ttl=64 time=0.875 ms
user@laptop:~$ ping 192.168.0.5
PING 192.168.0.5 (192.168.0.5) 56(84) bytes of data.
64 bytes from 192.168.0.5: icmp_req=1 ttl=64 time=0.774 ms
64 bytes from 192.168.0.5: icmp_req=2 ttl=64 time=0.747 ms
From workstation (192.168.0.5)…
user@workstation:~$ ping 192.168.0.55
PING 192.168.0.55 (192.168.0.55) 56(84) bytes of data.
64 bytes from 192.168.0.55: icmp_req=1 ttl=64 time=0.754 ms
64 bytes from 192.168.0.55: icmp_req=2 ttl=64 time=0.720 ms
user@workstation:~$ ping google.com
PING google.com (74.125.224.110) 56(84) bytes of data.
64 bytes from nuq04s08-in-f14.1e100.net (74.125.224.110): icmp_req=1 ttl=46 time=90.6 ms
64 bytes from nuq04s08-in-f14.1e100.net (74.125.224.110): icmp_req=2 ttl=46 time=92.2 ms
From laptop…
user@laptop:~$ ping 74.125.224.110
PING 74.125.224.110 (74.125.224.110) 56(84) bytes of data.
64 bytes from 74.125.224.110: icmp_req=1 ttl=46 time=105 ms
64 bytes from 74.125.224.110: icmp_req=2 ttl=46 time=91.5 ms
64 bytes from 74.125.224.110: icmp_req=3 ttl=46 time=92.2 ms
64 bytes from 74.125.224.110: icmp_req=4 ttl=46 time=89.3 ms
And also from laptop (using sudo)…
root@laptop:~# ps -e | grep bind
root@laptop:~# ps -e | grep net
   17 ?        00:00:00 netns
root@laptop:~#
Additional information…
The laptop is dual boot, and with the same hardware Windows has no DNS problems. Also, there are three connection methods to the internet, two WiFi APs and a wired connection. This problem occurs on all three.
Skype seems to work, having no problems connecting to its network.
This Lenovo S12 (Intel atom) laptop does not seem to play nice with Linux/Ubuntu as several custom work-arounds are required to get Ubuntu working ⋯ e.g. needing WiCd because Network Manager does not work. More here, here, here, and here.
muru
  • 207,228
5 Answers5
I'm having the same issue. I've found that if I disconnect and reconnect to my wifi network, or if I reboot the machine, I can get one or two webpages to load, but then DNS stops working again. For the record, just because you can ping by IP, that doesn't mean that DNS is working. DNS is the service that turns names into IP addresses. Something odd that I did notice though, if I tether my laptop to my phone, internet works perfectly without a hitch. However, my home wifi network doesn't work for more than one webpage with Ubuntu even though it works with every other computer and device in the house.
Isaac
Unfortunately this is another "not an answer". It is just a problem isolation suggestion.
You've already confirmed via ping that IP networking appears to be working correctly on your laptop. The next thing I would try is using someone else's DNS servers. I do not know why the default DNS servers provided by an ISP sometimes tend to flake out, just that they appear to do so.
The most common "other" DNS servers to try are Google's public DNS and/or OpenDNS. Since both are free, why not try both? :-) Below are the IP addresses you can use and a suggested terminal command to test them with. (dig (domain information groper) was suggested in this answer).
Google Public DNS (Domain Name System)
    8.8.8.8
    8.8.4.4
OpenDNS
    208.67.222.222
    208.67.220.220
irrational@VBubu04-21daily:~$ dig  www.askubuntu.com @208.67.220.220
; <<>> DiG 9.8.1-P1 <<>> www.askubuntu.com @208.67.220.220
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 56386
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;www.askubuntu.com.     IN  A
;; ANSWER SECTION:
www.askubuntu.com.  1601    IN  A   64.34.119.12
;; Query time: 43 msec
;; SERVER: 208.67.220.220#53(208.67.220.220)
;; WHEN: Mon Apr 23 13:26:18 2012
;; MSG SIZE  rcvd: 51
Eliminating Router "DNS Relay"
Another "For What It's Worth" digression suggestion. The default nameserver in your system turns out to be your router, i.e. /etc/resolv.conf == nameserver 192.168.0.1. In other words, your router is playing the role of a DNS server.
Your systems send their DNS requests to your router and it forwards them on to whatever DNS the router is set up to use. The router should then forward any response returned from the DNS server to the system on your LAN which originally sent the DNS request.
I suppose whether or not this is a good thing depends on how you look at it. Being cynical, I tend to view this as adding yet another, unneeded middleman who could cluck things up to the processing. So I don't do this. Instead I configure my router to provide the IP addresses for the Google and/or OpenDNS DNS servers to any system on my LAN as part of its DHCP response.
The method to do this probably varies depending on the router's manufacturer. I have a D-Link 655 and the steps I have to follow are:
  • Log on to my router as admin.
  • Disable the DNS Relay checkbox in the Network Settings > Router Settings section of my router's setup.
  • Add the DNS IP addresses to supply via DHCP to the WAN (Internet) > DHCP section of my router's setup.
Rebooting your router is probably the quickest way to see if your router might part of the problem you're having. If it is ... or even if it isn't :-) ... you might consider the change suggested above.
Resolution discovered.
/etc/resolv.conf is being deleted. How or why is undetermined.
It may be due to the fact that changing DNS in WiCd does not result in resolv.conf being changed.
Thanks to all for the suggestions.
Same problem, router and local DNS addresses were OK but I could only access websites directly through IP addressing.
Somehow /etc/resolv.conf was patched and the first (of 3) nameservers had an IPv6 address while my internet-provider does not offer IPv6 yet. After deleting the IPv6 address the issue was solved.
Nephente
  • 5,875
RobNL
I had something similar happen on a Mint laptop. I came to this and similar questions through a search on "DNS stopped working". My wired connection was perfectly fine and the wifi connection sorta worked except for DNS. And even DNS worked sometimes.
I tried a lot of suggestions with no luck. I finally solved it when I came across the suggestion to run this command:
sudo dpkg-reconfigure resolvconf
