If I run any snap command it fails.
I found out that snapd service is not running. I tried to start it but this error showed up
Job for snapd.service failed because the control process exited with error code.
See "systemctl status snapd.service" and "journalctl -xe" for details.
I ran journalctl -xe and this is the output أبريل 29 03:15:09 Ryok
snap-failure[48189]: error: snapd failed: exit status 1 أبريل 29 03:15:09 Ryok systemd[1]: snapd.failure.service: Main process exited,
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- An ExecStart= process belonging to unit snapd.failure.service has exited.
-- The process' exit code is 'exited' and its exit status is 1. أبريل 29 03:15:09 Ryok systemd[1]: snapd.failure.service: Failed with result 'e>
-- Subject: Unit failed
-- The unit snapd.failure.service has entered the 'failed' state with result 'e> أبريل 29 03:15:09 Ryok systemd[1]: Failed to start Failure handling of the snap>
-- Subject: A start job for unit snapd.failure.service has failed
-- A start job for unit snapd.failure.service has finished with a failure.
-- The job identifier is 14440 and the job result is failed.
if i try for example
snap install postman
this error is thrown
error: cannot communicate with server: Post http://localhost/v2/snaps/postman: dial unix /run/snapd.socket: connect: connection refused
Snap version
snap    2.44.3+20.04
snapd   unavailable
series  -
OS : Ubuntu 20.04 LTS
I tried reinstalling it and uninstalling then installing but it didn't work. I read a lot about it but no solution seemed to solve the problem.
Thanks for your time
Zanna
  • 72,312
RYOK
  • 145
I think it is probably the same issue as, here due to a system not including snapd,
Using Snap with Ubuntu on WSL
seems very hard to fix.
