After installing Tomcat (on Ubuntu 18.04) via apt install tomcat8, where to put the Java -Xmx option to increase available memory?
Asked
Active
Viewed 1,345 times
-1
Set an environment variable CATALINA_OPTS (or JAVA_OPTS) into a script named setenv.sh, in CATALINA_BASE/bin.
From the 'catalina.sh':
Environment Variable Prerequisites
Do not set the variables in this script. Instead put them into a script
setenv.sh in CATALINA_BASE/bin to keep your customizations separate.
CATALINA_OPTS (Optional) Java runtime options used when the "start",
"run" or "debug" command is executed.
Include here and not in JAVA_OPTS all options, that should
only be used by Tomcat itself, not by the stop process,
the version command etc.
Examples are heap size, GC logging, JMX ports etc.
OR
JAVA_OPTS (Optional) Java runtime options used when any command
is executed.
Include here and not in CATALINA_OPTS all options, that
should be used by Tomcat and also by the stop process,
Most options should go into CATALINA_OPTS.
Hildeberto
- 99
