I am trying to install MegaSync on my new ubuntu 20.04 installation =). They already have a version out for ubuntu 20.04. (See https://mega.nz/sync). However, when I try to install it with sudo dpkg -i megasync-xUbuntu_20.04_amd64.deb I get a big list of dependency errors. It seems to me Megasync is missing some packages. However when I open the software updater it says there are no new updates that need to be done. I am not so experienced with Ubuntu yet so any help would be greatly appreciated.
Selecting previously unselected package megasync.
(Reading database ... 195014 files and directories currently installed.)
Preparing to unpack megasync-xUbuntu_20.04_amd64.deb ...
Unpacking megasync (4.3.1-15.1) ...
dpkg: dependency problems prevent configuration of megasync:
 megasync depends on libc-ares2 (>= 1.7.4); however:
  Package libc-ares2 is not installed.
 megasync depends on libcrypto++6; however:
  Package libcrypto++6 is not installed.
 megasync depends on libmediainfo0v5 (>= 0.7.56); however:
  Package libmediainfo0v5 is not installed.
 megasync depends on libqt5core5a (>= 5.12.2); however:
  Package libqt5core5a is not installed.
 megasync depends on libqt5dbus5 (>= 5.0.2); however:
  Package libqt5dbus5 is not installed.
 megasync depends on libqt5gui5 (>= 5.8.0) | libqt5gui5-gles (>= 5.8.0); however:
  Package libqt5gui5 is not installed.
  Package libqt5gui5-gles is not installed.
 megasync depends on libqt5network5 (>= 5.1.0); however:
  Package libqt5network5 is not installed.
 megasync depends on libqt5svg5 (>= 5.6.0~beta); however:
  Package libqt5svg5 is not installed.
 megasync depends on libqt5widgets5 (>= 5.11.0~rc1); however:
  Package libqt5widgets5 is not installed.
 megasync depends on libzen0v5 (>= 0.4.31-2~); however:
  Package libzen0v5 is not installed.
dpkg: error processing package megasync (--install):
 dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu2) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
 megasync
Psychotechnopath
  • 853
  • 20
You have to use apt / apt-get instead of dpkg. They will install dependencies for package:
sudo apt install ./megasync-xUbuntu_20.04_amd64.deb
N0rbert
  • 103,263
-1
None of the solutions I found in the web worked so I tried the following:
I downloaded libcrypto++9 from here, and installed it as a .deb. http://archive.ubuntu.com/ubuntu/pool/universe/libc/libcrypto++/libcrypto++9_5.6.1-6_amd64.deb
The same for libc6 from: http://ftp.br.debian.org/debian/pool/main/g/glibc/libc6_2.31-4_amd64.deb
Then I downloaded libqt5gui5-gles_5.15.1+dfsg-2_amd64.deb from http://ftp.br.debian.org/debian/pool/main/q/qtbase-opensource-src-gles/libqt5gui5-gles_5.15.1+dfsg-2_amd64.deb
You should do it with any package that is missing in your own configuration. I recomend this website to find them: https://pkgs.org/
