I tried to open a pdf in my external HD with Evince (pdf reader), but apparmor denied. Then I tried to find Evince's profile to add a link to it in /etc/apparmor.d/disable in order to disable the profile. I used the command
aa-status
to find the profile. It shows:
snap.evince.evince
The apparmor manual page explains that some in the profiles list generated by the former command, the slashes are replaced by dots, so I tried to find /snap/evince/evince; it does not exist.
Then I tried to set the evince profile to "complain", instead of "enforce", using this command:
sudo aa-complain snap.evince.evince
Result:
Can't find snap.evince.evince in the system path list. If the name of the application is correct, please run 'which snap.evince.evince' as a user with correct PATH environment set up in order to find the fully-qualified path and use the full path as parameter.
I tried do use which and whereis to find the profile, but it was of no avail.
Then I used these commands:
sudo systemctl stop apparmor
sudo systemctl disable apparmor
I tried to open a pdf file with Evince, but AppArmor denied it. I rebooted and I am in the same situation.
Can I disable all profiles at once?
Can I disable a specific profile by any other mean?
P.S - I am asking this question because removing apparmor makes snap unusable, which is very counterproductive.
Thanks in advance.
I am using Ubuntu Budgie 20.04. LTS
lima
  • 71
If you execute the command sudo aa-teardown, then this will unload all AppArmor profiles. It works like a charm.
Flimm
  • 44,031
