I have the GNOME calendar installed and it works fine.
But there is a problem, it is not the default calendar and I can not select it. In the calendars category, only a text editor is available (apparently by mistake).
I am sure that this is a bug, and really look forward to fixing it in Ubuntu. In the meantime, I hope that someone will tell me how to fix this manually.
muru
  • 207,228
An even easier solution would be to set the value with gio itself. Thus, set with the command:
gio mime text/calendar org.gnome.Calendar.desktop
Then check what you just did with the following command:
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Try this
gedit /home/yourname/.local/share/applications/mimeapps.list
paste text/calendar=org.gnome.Calendar.desktop at the end of [default applications] and save.
by querying gvfs-mime --query text/calendar
you should get
Default application for 'text/calendar': org.gnome.Calendar.desktop
Registered applications:
dlin
  • 3,900
What worked for me was:
Open Terminal:
locate mimeapps.list
Find the path starting with home: /home/user_name/.config/mimeapps.list
Then run the below commands.
vim /home/user_name/.config/mimeapps.list
or
gedit /home/user_name/.config/mimeapps.list
(both vim and gedit allow you to edit text files)
paste text/calendar=org.gnome.Calendar.desktop under the last application in the default application list
Save the file and run the below command:
Note the following enter image description here
And lastly check your default applications under the Ubuntu settings: enter image description here
G Dube
  • 197
This is a bug of gnome. Already fixed in gnome 40 and Ubuntu 21.10.
