13
I'd like to mount /tmp without fstab entry using tmp.mount
However on Ubuntu 20.04 LTS, it doesn't seem to work.
user@user-x1:~$ systemctl status tmp.mount
Unit tmp.mount could not be found.
user@user-x1:~$ sudo systemctl enable tmp.mount
Failed to enable unit: Unit file tmp.mount does not exist.
user@user-x1:~$ sudo systemctl cat tmp.mount
No files found for tmp.mount.
user@user-x1:~$ cat /usr/share/systemd/tmp.mount
#  SPDX-License-Identifier: LGPL-2.1+
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
[Unit]
Description=Temporary Directory (/tmp)
Documentation=https://systemd.io/TEMPORARY_DIRECTORIES
Documentation=man:file-hierarchy(7)
Documentation=https://www.freedesktop.org/wiki/Software/systemd/APIFileSystems
ConditionPathIsSymbolicLink=!/tmp
DefaultDependencies=no
Conflicts=umount.target
Before=local-fs.target umount.target
After=swap.target
[Mount]
What=tmpfs
Where=/tmp
Type=tmpfs
Options=mode=1777,strictatime,nosuid,nodev
[Install]
WantedBy=local-fs.target
user@user-x1:~$
What's happening? Why does systemd say unit could not be found even though bash auto tabbing fills up tmp.mount and what's the simplest way to enable this tmpfs without any config?
x70766c
  • 133
tmp.mount is not enabled by default. Just copy and enable it
sudo cp -v /usr/share/systemd/tmp.mount /etc/systemd/system/
16
Note that systemctl enable accept absolute paths to unit files. (See systemctl man page) So there's no need to copy it manually.
I have tested on Ubuntu 22.04:
$ sudo systemctl enable /usr/share/systemd/tmp.mount
Created symlink /etc/systemd/system/local-fs.target.wants/tmp.mount → /usr/share/systemd/tmp.mount.
Created symlink /etc/systemd/system/tmp.mount → /usr/share/systemd/tmp.mount.
