I am using Kubuntu, and one very irritating feature in (K)ubuntu 20.04 is the enforcement of live usb disk checking at startup, and if you are not fast enough to press ctr-c then it will take minutes scanning (which is not needed for 99.99999999999% of the cases). So, is there a way to skip it by adding an option in the booting startup screen. Also, I made a remastered iso file of my system and the problem still exist in the remastered version. Are there any settings in the system I can change to disable disk checking in startup for the remastered version???
Thanks.
Removing Disk Check on Persistent USB's
The command line option fsck.mode=skip can be used to skip the disk check.
The line Checking disks: 0% complete will still come up but fsck will not be run, nor will boot time be increased.
mkusb After the Persistent USB drive is created, open /boot/grub/grub.cfg as root.
  • Add fsck.mode=skip to the Persistent menuentry thus:
    linux ($root)/casper/vmlinuz file=/cdrom/preseed/ubuntu.seed maybe-ubiquity fsck.mode=skip quiet splash persistent ---
  • Newer versions of mkusb already include this fix.
  • If you also wish to remove the Try Ubuntu / Install Ubuntu screen delete "maybe-ubiquity".
UNetbootin After creating the boot drive, open /boot/grub/grub.cfg as root.
  • Add fsck.mode=skip to the first menuentry for (UEFI boot mode).
  • Open syslinux.cfg as root and add fsck.mode=skip to the default menuentry for (BIOS boot mode).
Rufus After creating the boot drive, open /boot/grub/grub.cfg as root.
  • Add fsck.mode=skip to the Default menuentry for (UEFI boot mode).
  • Open /isolinux/txt.cfg as root and add fsck.mode=skip to the "Try Ubuntu without installing" menuentry, (for BIOS boot mode).
The Try Ubuntu / Install Ubuntu screen can be removed from BIOS boot by overwriting syslinux.cfg with:
default persistent
label persistent
  say Booting an Ubuntu Persistent session...
  kernel /casper/vmlinuz
  append  file=/cdrom/preseed/ubuntu.seed boot=casper persistent initrd=/casper/initrd quiet splash noprompt --
The Try Ubuntu / Install Ubuntu screen can be removed from Rufus UEFI boot by removing "maybe-ubiquity" from /boot/grub/grub.cfg.
C.S.Cameron
  • 20,530
  • 78
  • 125
