How can I install ike package (shrew soft vpn)? I have tried with the command suto apt install ike, but it didn't work for me. The output is:
Reading package lists... Done
Building dependency tree
E: Unable to locate package ike
I tried with deb package with the following command:
sudo dpkg -i ike-qtgui_2.2.1+dfsg-6_amd64.deb
But it didn't work:
Selecting previously unselected package ike-qtgui.
(Reading database ... 162541 files and directories currently installed.)
Preparing to unpack ike-qtgui_2.2.1+dfsg-6_amd64.deb ...
Unpacking ike-qtgui (2.2.1+dfsg-6) ...
dpkg: dependency problems prevent configuration of ike-qtgui:
 ike-qtgui depends on ike; however:
  Package ike is not installed.
 ike-qtgui depends on libqtcore4 (>= 4:4.7.0~beta1); however:
  Package libqtcore4 is not installed.
 ike-qtgui depends on libqtgui4 (>= 4:4.5.3); however:
  Package libqtgui4 is not installed.
dpkg: error processing package ike-qtgui (--install): dependency problems - leaving unconfigured Processing triggers for gnome-menus (3.36.0-1ubuntu1) ... Processing triggers for desktop-file-utils (0.24-1ubuntu2) ... Processing triggers for mime-support (3.64ubuntu1) ... Processing triggers for man-db (2.9.1-1) ... Errors were encountered while processing: ike-qtgui
Eliah Kagan
  • 119,640
The ike packages were dropped from Debian after Stretch (Released June 2017).
Correspondingly, Ubuntu dropped ike packages after 18.04.
You can build ike from source instead: Here's how
user535733
  • 68,493
