13
Recently, I completely erased the old disk data and installed the 20.04 LTS version of Ubuntu. However, Ubuntu software is not working properly. Also I can't even install the software. Please refer to the following: Why don't appear categories items in Ubuntu Software?
Therefore, I tried to reinstall the Ubuntu software by referring to the following documents, but the following error occurred:
Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:2 http://kr.archive.ubuntu.com/ubuntu focal InRelease
Get:3 http://kr.archive.ubuntu.com/ubuntu focal-updates InRelease [89.1 kB]
Hit:4 http://kr.archive.ubuntu.com/ubuntu focal-backports InRelease
Get:5 http://kr.archive.ubuntu.com/ubuntu focal-updates/main i386 Packages [648 B]
Get:6 http://kr.archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [2,000 B]
Fetched 91.8 kB in 2s (44.6 kB/s)
Reading package lists... Done
Building dependency tree
Package software-center is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'software-center' has no installation candidate
+ Update-1
The installed pkgs:
ii  appstream                                  0.12.10-2                             amd64        Software component metadata management
ii  brltty                                     6.0+dfsg-4ubuntu6                     amd64        Access software for a blind person using a braille display
ii  docbook-xml                                4.5-9                                 all          standard XML documentation system for software and systems
ii  espeak-ng-data:amd64                       1.50+dfsg-6                           amd64        Multi-lingual software speech synthesizer: speech data files
ii  gnome-software                             3.36.0-0ubuntu3                       amd64        Software Center for GNOME
ii  gnome-software-common                      3.36.0-0ubuntu3                       all          Software Center for GNOME (common files)
ii  gnome-software-plugin-snap                 3.36.0-0ubuntu3                       amd64        Snap support for GNOME Software
ii  libdv4:amd64                               1.0.0-12                              amd64        software library for DV format digital video (runtime lib)
ii  libespeak-ng1:amd64                        1.50+dfsg-6                           amd64        Multi-lingual software speech synthesizer: shared library
ii  libqpdf26:amd64                            9.1.1-1build1                         amd64        runtime library for PDF transformation/inspection software
ii  libtss2-esys0                              2.3.2-1                               amd64        TPM2 Software stack library - TSS and TCTI libraries
ii  python3-software-properties                0.98.9                                all          manage the repositories that you install software from
ii  software-properties-common                 0.98.9                                all          manage the repositories that you install software from (common)
ii  software-properties-gtk                    0.98.9                                all          manage the repositories that you install software from (gtk)
ii  xbrlapi                                    6.0+dfsg-4ubuntu6                     amd64        Access software for a blind person using a braille display - xbrlapi
+Update-2
Snap-list:
Name               Version                     Rev   Tracking         Publisher     Notes
chromium           81.0.4044.122               1123  latest/stable    canonical✓    -
core18             20200311                    1705  latest/stable    canonical✓    base
gimp               2.10.18                     252   latest/stable    snapcrafters  -
gnome-3-28-1804    3.28.0-16-g27c9498.27c9498  116   latest/stable    canonical✓    -
gnome-3-34-1804    0+git.2c86692               27    latest/stable/…  canonical✓    -
gtk-common-themes  0.1-36-gc75f853             1506  latest/stable/…  canonical✓    -
libreoffice        6.4.3.2                     177   latest/stable    canonical✓    -
snap-store         3.36.0-74-ga164ec9          433   latest/stable/…  canonical✓    -
snapd              2.44.3                      7264  latest/stable    canonical✓    snapd
bakuiseok
  • 303
Install
You can install Ubuntu Software like so:
sudo apt install ubuntu-software
or install Gnome Software in newer releases of Ubuntu like so:
sudo apt install gnome-software
Reinstall
You can reinstall Ubuntu Software like so:
sudo apt install --reinstall ubuntu-software
or reinstall Gnome Software in newer releases of Ubuntu like so:
sudo apt install --reinstall gnome-software
Reset
You can reset Ubuntu Software to its vanilla settings.
First, purge it like so:
sudo apt purge ubuntu-software
Then, install it like so:
or reset Gnome Software in newer releases of Ubuntu.
sudo apt purge gnome-software
Notice
You can remove Snap Store that might be already installed ( although I recommend you leave it ) like so:
sudo snap remove snap-store
and you can install Snap Store again like so:
sudo snap install snap-store
Raffa
  • 34,963
I heard they switched to snap store. You may try either of the two.
sudo apt-get update
sudo apt-get install gnome-software
OR
sudo apt-get update
You can try looking at the snap store website and downloading the store from there snap store
rodude123
  • 961
