32
Ubuntu 20.04 has Python 3.6 and Python 3.8 support. Command python3 -m venv my_venv creates virtual environment with python 3.8 and it works as expected.
However, trying python3.6 -m venv my_venv3.6 does not work. The response I get is /usr/bin/python3.6: No module named venv.
I tried using virtualenv --python=/usr/bin/python3.6 my_venv3.6, which results in:
RuntimeError: failed to query /usr/bin/python3.6 with code 1 err: ...
I also tried installing sudo apt install python3.6-venv which results in:
Reading package lists... Done
Building dependency tree
Package python3.6-venv is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python3.6-venv' has no installation candidate
Note that running python3.6 starts interactive python prompt with Python 3.6.9. I can also run scripts this way, so it seems that Python 3.6 is indeed usable on my system.
How can I start Python 3.6 virtual environment on Ubuntu 20.04?
Eliah Kagan
  • 119,640
obrusvit
  • 423
Ubuntu 20.04 ships with default Python 3.8. So first you will need to install Python 3.6.
  1. Install python 3.6:
    sudo add-apt-repository ppa:deadsnakes/ppa
    sudo apt-get update
    sudo apt-get install python3.6
  2. If the virtualenv package is not installed, run:
    apt-get update
    apt-get install python3-virtualenv
  3. Create a virtual environment:
    virtualenv -p /usr/bin/python3.6 venv
You can also do:
curl https://pyenv.run | bash
pyenv install 3.6.13
pyenv global 3.6.13
pyenv local 3.6.13
pip install virtualenv
virtualenv venv_ok
jmunsch
  • 2,293
  • 24
  • 30
