Anyone know how to see the space on squid? I mean the cache space on the squid that is being used, like the available space and used space of the cache itself, thanks!
Kees Cook
  • 17,823
Check squid cache configuration file for the size of squid cache.
Goto Terminal and type the following,
grep ^cache_dir /etc/squid/squid.conf
cache_dir ufs /var/spool/squid 15000 16 256
Here 15000 is your squid cache directory size.
NOTE: Please note that the squid configuration file is squid.conf
If you want to know how much data is currently cached,then type the following in terminal
sudo du -sh /var/spool/squid
18M /var/spool/squid
So 18MB data is currently cached here.
Jani Uusitalo
  • 893
  • 22
karthick87
  • 84,513
