I have one strange issue... It's heppening to me from ubuntu 19.10, and now It's same with 20.04. It's related for next two apps: * WPS office * cisco anyconnect
Both apps is started very slowly once when I started them, but this heppening only when I started them as a normal user. If I started them as a sudo user... They are started very quickly.
Do you have any suggestion what can be and how to check what can be. I tested kubuntu as well... and in kubuntu I don't have any issue.
Thanks,
This is most likely caused by the problem discussed here, [Some applications on Ubuntu 19.10 very slow to start
Along with the previous answers, I found the problem doesn't happen if you choose to Upgrade using the Release-Upgrade method. An easy method would be to install 18.04.4, then from that system install 20.04 by running sudo do-release-upgrade -d In my case the Internet Upgrade would take about 15 to 20 minutes and afterwards there wasn't any trouble with some Apps starting with a 25 second delay.
TBar
