I am creating a backup of .bashrc. I make a copy of it inside my backup folder. Let's say the folder is ~/backup
previously I always created a .hidden file and put the name of files I want to hide. But now the case is opposite, I am always trying to show the hidden file.
This is the closest I came across, but no luck !! Is it possible to have Nautilus show hidden files except for one specific folder? and How to always show some hidden files in Nautilus?
I have tried !.bashrc in .hidden file.
Here is a screenshot to emphasize simplicity. ANY IDEAS??
raz
  • 1,882
The direct feature to selectively show hidden files is not available. The user case is also not quite clear. In principle, it is easy enough to hit Ctrl+h to quickly see a file you know is normally hidden.
There are workarounds you can use to achieve what you want, but unless you indicate why you would want to achieve this, it is a bit guessing.
If the reason is that you want quick access to a hidden file, i.e., for quick opening and editing, then you could create a link to the file, e.g. a link bashrc to the file .bashrc in the same directory. That is not more overhead than editing a .hidden configuration file.
That way, you see a file anytime that gives quick access to the hidden file.
Hard link or symbolic link?
In the old days, I would have recommended to make a hard link. However, graphical editors, upon saving, may make a copy and then rename the copy when the changed file is saved. This breaks the hard link. Therefore, I would recommend a symbolic link, that always links to the same file name, even if its inode has changed.
vanadium
  • 97,564
