tried installing normal pgAdmin with Apache2 hosting, but that obv. conflicted with nginx
it won't if you configure Apache2 to listen to different port that nginx didn't use.
pgAdmin does not seem to play well with nginx
install and configure uWSGI with pgAdmin app, then configure nginx to use uwsgi_pass to communicate to uWSGI.
Edit 2020-05-10: More details and information
You got two solutions here, either use nginx + uwsgi_pass, or Apache httpd + mod_proxy_wsgi. Let's delve into both.
Prerequisites
Python and Python development headers
Install Python and its compatible development headers, preferably Python >=3.6. PCRE 3 libraries are required for uwsgi to handle regex routings.
$ sudo apt-get update && apt-get -y install build-essential python3 python3-dev libpcre3-dev libpcre3
Python virtual environment
Install your pgAdmin on a virtual environment, whether it's venv, virtualenv, conda, anything even; just to make sure that your OS package manager won't interfere with your python environments (versions, packages, etc).
If you're using venv, it should be something like
$ cd /path/to/working_directory
Install virtual environment on .env, and activate it.
$ python3 -m venv .env
$ source .env/bin/activate
upgrade existing pip packages, and install wheel.
(.env) $ pip install --upgrade pip setuptools
(.env) $ pip install wheel
install pgAdmin 4.21
(.env) $ pip install https://ftp.postgresql.org/pub/pgadmin/pgadmin4/v4.21/pip/pgadmin4-4.21-py2.py3-none-any.whl
uWSGI and pgAdmin
uWSGI Installation
To let your webserver connect to pgAdmin, you'll use WSGI or HTTP server. pgAdmin supports uWSGI and Gunicorn.
Here, we'll use uWSGI, but if you're using another WSGI server, just make sure that it's listening at UNIX socket /tmp/wsgi/pgadmin.sock
First, you'll need to install uWSGI. You can install uWSGI with apt-get or with pip.
Both are fine; but with pip, you'll need to write your own service file; and with apt-get, you'll need to accept you're using older version of uWSGI. We'll install both, using Ubuntu-distributed service file and pip-distributed latest version uwsgi binary
Install Ubuntu-distributed uwsgi
$ sudo apt-get -y install uwsgi
Install pip-distributed uwsgi
$ source /path/to/working_directory/.env/bin/activate
(.env) $ pip install uwsgi
Ubuntu-distributed version
(.env) $ /usr/bin/uwsgi --version
2.0.15-debian
pip-distributed version
(.env) $ uwsgi --version
2.0.18
service file
(.env) $ ls /etc/init.d/uwsgi
/etc/init.d/uwsgi
pgAdmin Installation
Next, we're setting pgAdmin up for uWSGI. You'll need to get into our virtual environment again. We're roughly following this pgAdmin official guide.
First, create a local configuration.
$ cd /path/to/working_directory/.env/lib/python3.6/site-packages/pgadmin4
$ cp config.py config_local.py
$ vim config_local.py
Note that you can follow pgAdmin's documentation, but we can just edit DATA_DIR = '/var/lib/pgadmin' to anything sensible, because everything else will refer to DATA_DIR. Here, we use /path/to/working_directory/lib
Next, create pgAdmin's required directories
$ sudo mkdir -p /var/log/pgadmin
$ mkdir /path/to/working_directory/lib
/var/log/pgadmin and DATA_DIR should be fully controlled by uWSGI, because pgAdmin will be running under uWSGI. Here, we'll be using www-data as uWSGI user and group.
$ sudo chown www-data:www-data /var/log/pgadmin /path/to/working_directory/lib
Note that we need to allow writes to /var/log/pgadmin and DATA_DIR to let it set up. We only let it be writable by our user now, and we will fix this permission later.
$ sudo chmod 777 /var/log/pgadmin /path/to/working_directory/lib
Enter our virtual environment and run pgAdmin's setup.py.
(.env) $ cd /path/to/working_directory/.env/lib/python3.6/site-packages/pgadmin4
(.env) $ python setup.py
Follow setup instructions until it's complete, and take note of your email and password created here.
Next, fix /var/log/pgadmin and DATA_DIR permissions.
$ chmod 755 /var/log/pgadmin /path/to/working_directory/lib
$ chown -R www-data:www-data /var/log/pgadmin /path/to/working_directory/lib
pgAdmin should be completely set up by now.
Integrating uWSGI and pgAdmin
Now, we're ready to integrate pgAdmin and uWSGI, creating WSGI server that listens at UNIX socket /tmp/wsgi/pgadmin.sock.
First, using your favorite editor, create a uWSGI configuration file in /etc/uwsgi/apps-available. Let's call it pgadmin.ini.
$ sudo vim /etc/uwsgi/apps-available/pgadmin.ini
It should contain at least:
[uwsgi]
socket = /tmp/wsgi/pgadmin.sock
chdir = /path/to/working_directory/.env/lib/python3.6/site-packages/pgadmin4
manage-script-name = true
venv = /path/to/working_directory/.env/
master = true
processes = 1
threads = 4
mount = /=pgAdmin4:app
log-format = %(addr) - %(user) [%(ltime)] "%(method) %(uri) %(proto)" %(status) %(size) "%(referer)" "%(uagent)"
logger = file:/tmp/wsgi/pgadmin-access.log
uid = www-data
gid = www-data
create required directories, and enable our pgAdmin uWSGI app
$ sudo mkdir -p /tmp/wsgi
$ sudo chown www-data:www-data /tmp/wsgi
$ sudo ln -s /etc/uwsgi/apps-available/pgadmin.ini /etc/uwsgi/apps-enabled/pgadmin.ini
copy default uWSGI file to another service file, and edit it to use pip-installed uWSGI binary.
$ sudo cp /etc/init.d/uwsgi /etc/init.d/uwsgi-venv
$ vim /etc/init.d/uwsgi-venv
# replace DAEMON="/usr/bin/uwsgi" to DAEMON="/path/to/working_directory/.env/bin/uwsgi
uWSGI configuration should be done.
Now, try to start uWSGI.
$ sudo service uwsgi-venv start pgadmin
Here, pgadmin refers to what we've soft-linked in /etc/uwsgi/apps-enabled before. If you linked it as pgadmin.ini, you'll use pgadmin.
Check if uWSGI is running.
$ ps -eF | grep uwsgi
www-data 10582 1 2 32144 91480 0 03:56 ? 00:00:03 /path/to/working_directory/.env/bin/uwsgi --ini /usr/share/uwsgi/conf/default.ini --ini /etc/uwsgi/apps-enabled/pgadmin.ini --daemonize /var/log/uwsgi/app/pgadmin.log
www-data 10593 10582 0 87443 2640 0 03:56 ? 00:00:00 /path/to/working_directory/.env/bin/uwsgi --ini /usr/share/uwsgi/conf/default.ini --ini /etc/uwsgi/apps-enabled/pgadmin.ini --daemonize /var/log/uwsgi/app/pgadmin.log
nginx and uWSGI
If you haven't installed nginx, install it with apt-get.
$ sudo apt-get -y install nginx
If you have already installed nginx, you may need to adjust some configurations. Let me know if you had any trouble then.
Next, let's configure nginx so that it'll pass any requests to uWSGI we configured earlier.
In /etc/nginx/sites-available directory, create a new nginx configuration file. Here, we're using pgadmin.local as virtual hostname.
$ sudo vim /etc/nginx/sites-available/pgadmin.conf
This configuration file should look at least like this:
server {
listen 80;
server_name pgadmin.local;
location / {
include /etc/nginx/uwsgi_params;
uwsgi_pass unix:/tmp/wsgi/pgadmin.sock;
If you need it to listen to other port, change listen 80; to listen <your_port>;.
Enable this configuration.
$ sudo ln -s /etc/nginx/sites-available/pgadmin.conf /etc/nginx/sites-enabled/pgadmin.conf
Test and reload your new nginx configuration.
$ sudo nginx -t && sudo service nginx reload
Depending on your configuration, you may need to configure your firewall after this, but after that, you can browse to your configured virtual host with your favorite browser.
$ firefox http://pgadmin.local
httpd and uWSGI
There's not a lot of difference between httpd and nginx configuration here, you just need to forward http request as WSGI request to WSGI server backend, in this case, using mod_proxy_wsgi.
Install httpd first if you haven't installed it yet.
$ sudo apt-get -y install apache2 apache2-utils
If you have already installed httpd, you may need to adjust some configurations. Let me know if you had any trouble then.
Don't forget to install mod-proxy and mod-proxy-uwsgi, as both these modules are required.
$ sudo apt-get -y install libapache2-mod-proxy-uwsgi
Next, let's configure httpd to pass any requests to uWSGI we configured earlier.
In /etc/apache2/sites-available directory, create a new virtual host configuration file. Here, we're using pgadmin.local as virtual hostname.
$ sudo vim /etc/apache2/sites-available/pgadmin.conf
<VirtualHost *:80>
ServerName pgadmin.local
ProxyRequests off
ProxyPass "/" "unix:/tmp/wsgi/pgadmin.sock|uwsgi://localhost/"
</VirtualHost>
If you need it to listen to other port, you'll need a few changes.
Change <VirtualHost *:80> to <VirtualHost *:<your_port>>
In /etc/apache2/ports.conf, remove all irrelevant Listens including those under <IfModule>s, and add Listen <your_port>.
If you still have default site enabled, disable it with a2dissite.
$ sudo ln -s /etc/apache2/sites-available/pgadmin.conf /etc/apache2/sites-enabled/pgadmin.conf
Enable mod_proxy and mod_proxy_uwsgi
$ sudo a2enmod proxy proxy_uwsgi
Test and reload your new httpd configuration.
$ sudo apachectl configtest && sudo service apache2 reload
