With the new release of 20.04 LTS. How can I upgrade my 19.04 to this newest version? Or do I have to upgrade to 19.10 first?
Check out this link on how to do it: https://www.howtogeek.com/351360/how-to-upgrade-to-the-latest-version-of-ubuntu/
Yes you will have to upgrade to 19.10 first I believe. Basically, here's the steps:
  1. Since ubuntu normally only tells you to upgrade when there is an LTS version out, you will need to change that in order to prevent any problem during the installation. Use your preferred editor and type: sudo nano /etc/update-manager/release-upgrades At the bottom, you should see the text prompt=lts. If you see that, change the lts to normal. However if you don't see it you are good.
  2. run the command do-release-upgrade -c This command checks Ubuntu’s servers for any available updates and informs you which version of Ubuntu you’ll be upgrading to.
  3. The previous command checks for available updates, and if you see the current update that you want to upgrade to, execute the command, sudo do-release-upgrade.
  4. Just follow along with what the command lines tell you and you should be good to go!
I apologise for the unconventional styling of this answer, I am new and don't quite know the syntaxes yet. For the most accurate answer check the link I put at the top.
A person
  • 116
