I have 7Gb available but...
~ # dpkg --configure -a
Setting up linux-image-2.6.32-31-generic-pae (2.6.32-31.61) ...
Running depmod.
update-initramfs: Generating /boot/initrd.img-2.6.32-31-generic-pae
gzip: stdout: No space left on device
update-initramfs: failed for /boot/initrd.img-2.6.32-31-generic-pae
Failed to create initrd image.
dpkg: error processing linux-image-2.6.32-31-generic-pae (--configure):
 subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-generic-pae:
 linux-image-generic-pae depends on linux-image-2.6.32-31-generic-pae; however:
  Package linux-image-2.6.32-31-generic-pae is not configured yet.
dpkg: error processing linux-image-generic-pae (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic-pae:
 linux-generic-pae depends on linux-image-generic-pae (= 2.6.32.31.37); however:
  Package linux-image-generic-pae is not configured yet.
dpkg: error processing linux-generic-pae (--configure):
 linux-generic-pae
~ # df
Filesystem           1K-blocks Used Available Use% Mounted on
/dev/sda3             18577148  10255512   7377972  59% /
none                   1026416       164   1026252   1% /dev
none                   1030624         0   1030624   0% /dev/shm
none                   1030624       100   1030524   1% /var/run
none                   1030624         4   1030620   1% /var/lock
none                   1030624         0   1030624   0% /lib/init/rw
/dev/sda1                93207     87960       435 100% /boot
~ # lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 10.04.2 LTS
Release:    10.04
Codename:   lucid
Any idea why this is failing?
Whippy
  • 791
You have a separate /boot partition and it's 100% full:
~ # df
Remove some older kernels and try again.
Update: By "remove kernels" I mean "use apt-get or synaptic or the method described in the article found by @Whippy", not "remove kernel files and directories manually" - the latter would not be a good idea.
See also:
Sergey
  • 44,353
